For those of you who got the wrong driver or got the right driver, but it is faulty, or only does low amps, please PM me.
In your PM to me, include the following:
Order number
Date you ordered
Date you received it
Exactly what the problem is (Example:) " My light will only put out 1 amp on high, with the East092 driver." OR "My driver was not an East092 driver, it was an XXXX driver (include the numbers on the driver if you can)"
According to my contact, a replacement light or money back can be done.
For those of you that have some other issue, then PM me and I will see what I can do.
I also got the “bad light”, non-DD low A driver with noise/pwm on high, without XML2, and no plastic ring around the LED (pre-smashed box of course, but so what)…I think any/all variations were possible.
Thanks OL for the follow up. But in all honesty, does this mean someone at TMart will cover this, or are you just going to hide the fact you will make good on peoples woes? As thats the Chinese lottery, we all know it, or should. Its not your responsibility if we all roll the dice and some of come up craps?
I have no idea what driver I got, as yet I cant get it out. I dont have a pair of circlip pliers small enough. Not even will the edge of a pair of little pliers from my mini set hold the notch.
Mine (no name) arrived in the same physical condition except the dust and I got a sleeve of bubble wrap, long enough to cover the length of the light, but not the lens lol. And yes, the tail cap was at the closed bottom of the bubble wrap sleeve, not the lens. Crushed white box, in a thin plastic bag, but as someone else stated, no damage that Ive noticed yet.
But you know, less than $30, delivered. I wasnt expecting foam padding. And I planned this as my first mod, with XML2, so was going to change everything but the host, switch (OL says they can handle it so Ill smoke test it) and reflector. Even the lens is in for an upgrade if I can get an AR one.
Sharp idea that one. It might work, but I aint gonna find out. Im off to town to get myself some smaller circlip pliers… and a coffee.
Edit:I ended up getting it out with a fine(ish) point head punch. They are hard to realign without cross threading. Mine is a really dark blue, not green, so what did I get?
Edit 2: I like this new monitor. Im going to photograph everything i need to inspect now, just loaded up a pic of the driver, and clear as a bell, East 092.
Well I think with the send date and your address they can probably check which warehouse it came from and maybe know by that which ones were the crappy ones I’m guessing?
Tmart will cover the problem with new lights or money back, depending on what you want. Just PM me with the info I requested and I will have Tmart contact you.
I still didn’t receive mine but it’s the same case as with Streamer, ordered on 3/22/14, backordered until 3/27/14, shipped 3/28/14.
I expect it somewhere between next tuesday and friday…
