I would say, the sooner the better. I do not expect anyone to have to pay shipping. I am sure they will just send a new light or you can just have the refund. Not worth it for anyone, to ship anything back.
so sorry about what you said.
We are discussing with manufacturers.
Please help me tell other members who dont received right flashlight. we will resend the right flashlight with East-092 or return money.
Thank you very much
Anybody with an issue reply to Old-Lumen's post #137 above ^^^^^^^^^
Received my no name one!
Nice light, looks good. Seems to have good output.
I tried to measure tailcap current but it looks like my multimeter is not capable of doing that anymore, can’t get a reading anymore. But there is no PWM on high, there is on other modes.
So I assume I got the right thing?
Don’t have the time right now to check up how to remove the driver to see if it really is what it should be.
So I assume I got the right thing?Don’t have the time right now to check up how to remove the driver to see if it really is what it should be.
Just pop the head off the battery tube, and look at it from the spring side, if its dark blue, its likely the EAST092 driver. My no name was, and it works fine, seems to have good throw. Not that I have another HD2010 to compare it too.
And I just held the pill in my hand, and used a pointy punch to spin the retaining ring out.
Hi
Dumb question but should the no-name 2010 have a Centering ring over the LED?
Just took my 2010 apart after re-watching the modding video,because beam is way weaker and fuzzier than my Ultrafire HD2010 maybe half as bright and not in focus.
I notice that the dome on the LED has on one side a rough/scuffed/haze on the surface. Is that just the luck of the draw or could it be from not having a centering ring around the LED?
Hi
My no name has the centering ring. Your star looks not to be firmly fixed down either.
Alright… That was easier than I thought. So this is the wrong driver I guess. !{width:40%}http://www.plaatjesdump.nl/upload/bec6b40a268b724de8e21843feec9a7c.jpg!:http://www.plaatjesdump.nl/upload/bec6b40a268b724de8e21843feec9a7c.jpg !{width:40%}http://www.plaatjesdump.nl/upload/0f44d7825cf176a9228cab5bd7abde05.jpg!:http://www.plaatjesdump.nl/upload/0f44d7825cf176a9228cab5bd7abde05.jpg
Yep, that's the suspect driver.
There is adhesive under the star, but because they forgot the centering ring, the star didn’t get pressed down against the pill by the reflector so the adhesive is a thick blob that probably isn’t transferring the heat very well.
Just wondering, who hasn’t received their light yet?
I ordered the no name on the 22nd, shipped the 27th. Still waiting.
My no name came today. XM-L2 led too!
we are in the same boat…
Got mine today… no name in grey color… bad driver but good XM-L2, can’t win them all I guess.
now… how are we going to get the good driver? sending the whole light back to china is out of the question
Mine also arrived this saturday. Seems legit, grey and no name. Dunno what driver is installed, I do wait for my tools…
Overall build quality is good, nothing like “white dust” or something else.
Still waiting here too.
Edit: apparently it was shipped via Sweden post from the Hong Kong warehouse to my address IN Hong Kong via Singapore. Still waiting.
I’m waiting too ;(
Got mine today… no name in grey color… bad driver but good XM-L2, can’t win them all I guess. now… how are we going to get the good driver? sending the whole light back to china is out of the question
See post 137.
http://www.tmart.com/TangsFire-HD-2010-CREE-XML-T6-6W-1200LM-5-Mode-Waterproof-Flashlight-Black_p144456.html 20 more pieces right now. Best they can scrounge up. use code t2m0a1r0t Looks like both coupons have expired due to out of stock. Apologies if everyone did not get what they wanted. Tmart Group Buy Coupon Codes Tangsfire HD2010 Coupon code is: t2m0a1r0t Ultrafire/No Name HD2010 Coupon code is: ttfmhrdt I still have to find out …
I’m waiting too ;(
This…
Got mine today, no name model, and gray? but a little brownish, like that one http://www.tmart.com/UItraFire-CREE-XM-LT6-8W-1300-Lumen-5-Mode-LED-Flashlight-Gray_p135765.html
Led is XM-L2, driver is not East092 (look on photo). Oring on head was broken, I think some one put too small oring on big head, unfortunately too big…
Pill has a very short thread, about half of normal pill from Old Lumens video.
Current in high mode is about 2,5A with fresh samsung cell.
Got mine today, no name model, and gray? but a little brownish, like that one http://www.tmart.com/UItraFire-CREE-XM-LT6-8W-1300-Lumen-5-Mode-LED-Flashlight-Gray_p135765.html Led is XM-L2, driver is not East092 (look on photo). Oring on head was broken, I think some one put too small oring on big head, unfortunately too big… Pill has a very short thread, about half of normal pill from Old Lumens video. Current in high mode is about 2,5A with fresh samsung cell.
That O-ring does not belong on the pill. Causes fitment problems and POOFS!
Old Lumens even removes his.
Hi OL. Got a question on Tangsfire HD2010.
Turns out, I had to remove the pills o-ring to get the reflector to seat properly. With the o-ring installed, it jams the reflector base into the star/solder connections when I screw the bezel back on. Works fine without the pill o-ring save for losing waterproofness.
I’m assuming this is what caused my short from the getgo. It melted/deformed the centering spacer slightly as a result.
Have you seen this on any of the HD2010’s you have handled? TIA….David
Yes, I only had one that had the O-ring, but I had to remove it. It caused interference, as you describe.
