[Sold out] 8 Purple Samsung ICR18650-28A $10 shipped
The only problem I see here is he doesn’t have enough flashlights :slight_smile:
DayLighter, because these cells are already sitting at the perfect storage voltage of 3.7, I would not charge them up until you actually need them. Cells charged up to 4.2V can loose upwards of 20% capacity (not charge) in 1 year at room temperature, but only about 4% at 3.7.
Other deals that we have come across, where the pulled cells are sitting a little low, I would charge up as soon as possible. For storage purposes, what I don’t know is would it be best to charge them up to 4.2 first and then discharge to 3.7 or only go straight to 3.7. Does anybody know?
Lets face it, we all have problems. Some worse than others. Daylighter on the other hand is in a different league all together. lol!
I don’t think it would matter too much because it’s only one (or even less) battery cycle.
I would charge it up to 4.20V and see how well it holds the voltage. A lot of my bad cells would drop right back to 4.10V because of their high internal resistance.
In real usage, I don’t think I would notice even a 20% reduction in capacity because I don’t use my lights continuously.
Ooops, missed this. These are not the easiest packs to open, not a good one to start with. I've done several other packs and this one was a challenge. Cells are packed tight in, glued very well, etc... Plastic though is thin and plyable -- you must be careful though, go slow, don't lose your patience. I used small tools - small cutter and a needlenose on this one. A small wire cutter is good enough to make cuts in the plastic, then the needlenose to pull/peel back - never pry because prying may be leveraging against a cell, which will damage it. You can start at a end or at the ridge where the electronics is - I did both ways. I try to get to wires to the driver first and cut them to avoid sparks.
Tabs are tack welded, pull them off carefully, gently, get as much off as you can with needlenose. What remains I dremel off with a dremel sanding drum. + end is heavier duty metal, but "-" end you have to be very careful with.
I only messed up one cell - grounded, got some sparks at the "+" end, but cell was fine. Simply pulled off the wrapper and re-wrapped with 18650 shrink wrap but to patch the small hole in the wrapper on the edge at the + end.
+1, my thoughts exactly..hindsight...sighhhhhh
Tom, it's done. I used a screwdriver at the connector and spread the case apart a little bit. From there I used small lineman's pliers, carefully peeling away the casing. After I removed the batteries, I rolled off the welded tabs with a pair of needle nose pliers. I used a Dremel to smooth out the burrs on the + and - connections., then cleaned the batteries. I didn't damage any of them. I've got 4 of them charging now.
What’s that charger?
They are Xtar VP1 chargers. I love them so much, I hardly use my hobby chargers anymore, except for checking my cells.
BTW, the displays work and look great, accurate too. The camera flash makes them look really dim
Nice work Glenn! Better than me...
Thanks Tom, but nobody's better that you pal :)
This is what the case looks like. lol!
Actually I’m running out of room on my shelf… especially with another 12 coming from Aliexpress spring festival sale :weary:
look like I have to do some spring cleaning sale too :stuck_out_tongue:
Holy shit!
So sic Kenny and that's with some missing (by me)! This is why I scatter mine around...
Good idea Tom… the problem is when I scatter it around the room, I won’t know if it’s missing or not :wink:
Kenny, we should get together along with Tom (if he's willing) sometime. We'll have a barbeque at my house. What do you think?
HOLY CRAP
sure Glenn… BBQ at night? so we have excuse to use our flashlights lol…j/k yeah sure let me know when is good for you and I’ll check the schedule with the wifey :slight_smile:
Willing ? Only at night though - we'll provide the lights! Ohh - I'll definitely bring the beers. Have you been to the Forest Pork store in your neighborhood? Wow - my favorite BBQ meats, but I'm into the German sausages, but they got lots of other goodies to grill. Even their hot dogs are the best around...
Kenny, that would make sense. Barbeques are always so much better at night anyway. My neighbors think I'm crazy spending so much money on this hobby. Having you here will convince them that I'm normal....lol!! just kidding. Your collection completely blew my mind! Seriously did! Anyway, it would be great to meet you in person, hopefully Tom too. Let's plan for sometime this summer, after I stain my backyard deck, and my lawn looking good. I like things looking perfect before I meet new people..
