hmm… I never try to light it that long, I should give it a try and see how long does it last on HIGH mode and see if there’s any protection against heat
Lights with electronic switches have always a parasitic standby current, how high this is depends on the driver. Just think of that(or test it) if you want to use a light in a glove box for longer periods….
Hmm . . . do these (particulalry the SC01 which I'm due to receive in a few days) do tailcap lockout easy enough because I do intend to keep it in a glovebox?
Well if anyone doesn’t like the SC01 then I can say the Roche F6 is flippin’ awesome for a few bucks more. I think it was $22 at Fasttech with the BLF discount.
Oh boy... The lowest I can set low seems to be 56 lumens. But... With the light off, if you hold the switch down, it starts ramping up, and the first level is 14 lumens. I'm really not sure though about the lowest you can set low mode. Seems like the #'s are all over the place, and once you raise low, it's hard to get it back low. ............ If you can understand that, I envy you!
This programmed low mode is rather confusing to me right now....
Edit: I can't seem to budge the head from the body tube - not sure if glued or one piece. I got the bezel off though, definite SS, 1 o-ring under the glass, nothing between the glass and bezel. The star is screwed down by 2 screws, there's definitely an aluminum plate that the aluminum star sits on. There's some thickness to the star/pill top combo. I tried pushing the driver out from the tube, and tried unscrewing the star/pill from the top - no luck either way. It seems like this may be it for the light.
Weird -- there are 3 wires soldered to the star, not two. Labeled: L-, L+, and V-. Anyone ever see anything like that? I haven't.
