I hope it’s very, very soon… ’cos I ordered 6 more it’s going to run out soon as this light become very popular and they might increase the price too :Sp
wow really? i thought the mini 01 was the brightest smallest 16340 there was.
shoot, im not up to date then haha.
now im gonna have to order one of these!
No - it has thermal grease under it, from the looks. The star definitely moves on the pill top when the screws are out.
"Bored out for 18350's?" - I'm no expert there, but the walls look pretty thin where the threads are, but the 18350's are close to fitting. In fact I was wondering if there are 18350's out there thinner than the ones I tried.
In the last pic above, you may notice a scratch on the right at the edge of the pill - this is where I tried unscrewing the pill with a needlenose, but to no avail - the needlenose slipped and put a deep scratch there.
I'd love to put in a XM-L2 T6 4C on copper, but the wiring looks iffy - '+' and '-' out the same hole, so if no slack, may not be able to do so. Also there's the mystery of the 3rd wire... If I could get the pill out, I'd upgrade the wires anyway.
Ooops, I'm thinking yes, scaled amperage in modes, so it's scaled accordingly. Didn't test that, but think I recall seeing it on in the lightbox for a moment. At work now, no access for another 8 hours or so.
I used eneloops and 14500’s on my sipik68 and yes eneloop gives out lower output when compared to 14500 battery
I would assume it will do the same thing on this light too
Mode Operation - this is how I understand how it works
With it OFF, hold the button for about 1.5 secs and it will come on in "very low" mode, 1 click will turn it OFF
With it OFF, one click it comes on in "low" mode, another click to "high" mode, next click OFF
With the light in "low" mode, hold the button and it starts ramping up, let go at anytime to set the new "low" mode. If you hit the max ramp setting, the light blinks twice. The max ramp is still lower than "high" mode
If you have the "low" mode max'ed out, holding the button will reset it back to the lowest value for "low" mode
With the light ON in either "low" or "high" mode, a double click will be strobe, then single click to exit strobe
The "very low" mode is a nice feature because you don't have to go through "high" to turn the light OFF, but definitely not as low as a moonlight mode.
More Details:
The tailcap lock-out feature works very well on both lights - 1/4 turn, light goes OUT - power is cut
For the SC01, KeepPower 840 mAh protected and Sanyo unprotected cells fit and work well
Can someone confirm the tint colour? Bluish, greenish or pure white? I just sold my S10 because I can’t stand the greenish and now looking for a replacement.
