Thanks Helios, I was all over that! 4.7 is quite different than 47.1! Works versus doesn’t work.
I find that the price of new components is well worth the effort as compared to stripping an existing driver. I’m not so good at taking those tiny resistors off a board without damaging them. To have a “tape” with 100 standing by, so much easier!
The price breaks start to lean towards buying individual components after you get up around 10 pieces. Fewer than that it's cheaper to use a donor driver for the parts.
Hey guys just checkin in, I have sets of BLF15DD’s and BFL17DD’s on the way. I got the 15’s to hopefully revive an old broken original 47’s quark (literally the original version). The 17mm is going in my HD2010.
Thanks to everyone that’s worked on these. I may be able to solder the SMD’s but I could never design them.
Stripping the drivers for components still takes time, perhaps it is free as you don’t charge yourself, don’t know. My Dad would figure in the cost of soldering iron tips, wear and tear on the soldering iron itself (they don’t last forever do they?) and the waste of a bare 105c board not being used. Every fraction of a penny counts. Me? I don’t like doing all that math so I just buy new ones and be done with it, keeps me from burning meself.
When I saw this board over at Oshpark I knew I had to try one. I haven't decided what to put it in yet and probably won't have time to do it for at least a few more weeks but there it sits...beckoning me. So much power in such a tiny little package.
I don't think I'll be going direct drive with this one...or maybe direct drive with a 15 second turbo timer and electronic switch??? Three of these mounted in an M6? Ultra-ultra mule? It pulled 14A from a single purple Efest 18350; I'm scared to see what it would do on a single 20R or VTC4.
Nah, I'll probably end up throwing it in an EDC tube type light and limiting it to around 6A and be reasonable for once.
Yes, the vias are completely filled with solder. Yes, I realize that this is potentially very dangerous. On most boards when the LEDs get too hot they tend to float off the board, shutting things off. Here they may float but there's nowhere to go and they may end up creating a short circuit instead. A short circuit with a high drain cell is not something you want to see!
All that heat in 20mm. On fr4. :~
I have the desire to place a large via or two under each xml thermal pad so that a short piece of solid core copper wire could be placed through there.
Are you concerns about heat with it? Does it have via’s under the center pads that you filled with something (copper wire/solder)? Is it 20mm? Looks awesome. Edit: question answered, didn’t see the next page after your post.
Is that an NCR18650BD back there? Any plans to add those to your store? I’d like to get a couple but after a disappointingly long wait on a set of NCR18650PF’s from FT (still waiting @ 38 business days) I don’t think I’ll be ordering any more batteries from over there.
Of course I'm concerned with heat! I think that I'm going to go the reasonable route and keep it around 6A...should be very efficient and not as crazy. Direct drive I think it would pull around 18-20A from a single 18650, way too much heat for that board and especially for a small 18650 tube light, even with a perfect thermal path. There are vias under each of the emitters which I filled with excess solder paste when I reflowed then smoothed off the excess on the underside after I was done.
Those cells are 2900mAh NCR18650s I bought from Wallbuys last year. The cells are decent but the protection circuits aren't so hot. I bought four of them and two of them trip with anything over 4A, the other two will do a hair over 5A before tripping...I know that at least two of them will run down to 2.5v resting without tripping the protection circuit. My son left my headlamp on for about 12 hours with two of them in there, when I found it the light was barely glowing. After about an hour each of the cells measured around 2.5v.
I have no idea, but thermally the 70N02 may be getting close to the limit at 30A, it is only rated for 31A continuous at 4.5V. If I were trying to run 30A I would not run the Led+ through the driver, instead running it directly from the battery. You would also need some serious wires, springs, etc. to handle over 30A.
Maybe put the emitter in a jar of mineral oil. In the center of the jar the heated oil will rise and make a thermal current to cool off the bundle of emitters. You could make a really nice camping lantern with that and a mayonnaise jar.
did i hear my name? i’m happy to answer questions about my boards if there are any. wish i found BLF earlier, you guys seem to be way more into diy than some other light forums i’ve been on…
