What would be a good way of reflowing the star to the pill?
Butane torch?
Soldering iron or frying pan will hardly give enough heat. And oven is not an option…
I got a XintD host here and an XP-G2 on noctigon. I never thought matching them but I wouldn’t worry about heat @3A anymore when they are soldered.
True and I do see your point. My concern is if I want to dedome the LED and for some reason the LED messed up and I need to replace it with a new one, I have to use something like a butane torch to do it by then. I wonder what method do they use to solder the Noctigon on the pill considering they need to do it fast (production) and good finishing.
I'm not sure what method they ended up using, although I did talk with them a few times along the way as they were preparing for this changeover. The obvious difficulty is in getting the LED centered.
The bare host (XinTD MTN) will still be available for those who want to build their own or modify without having to break out the blowtorch!
When I get my first copies I am planning on building two identical lights up at around 5.0A, one with the soldered MCPCB another with my typical Arctic Silver job held down tight by the reflector. I will then measure what kind of gains the directly bonded MCPCB offers by comparing the amount of lumens lost due to heat sag.
Well I overlook that one, I was keep thinking that it must be an XM-L2 inside lol. I can imagine that with the XP-G2 version by simply dedoming the LED it may gives around 100kcd if not more.
As for the XM-L2 version 3A is just “within spec”.
I have a 2 mode V3 XM-L U3 I'm extremely happy with. As much as I'm tempted to get a V5 XM-L2 U2, I think I'll hold off for a while until someone reviews it.
I had to reflow 3 LEDs in my Shadow SL3. I ordered the warm emitter version, but Fasttech sent me the cool version. I had to remove the electronics and the rubber switch cover then heat the entire head using the pre-heater in this hot air station. Worked great.
At $170 this might be slightly out of budget, though. :bigsmile:
But it will certainly get the job done.
I’ll borrow some kitchen gas burner, read somewhere they get up to 800°C, but can be adjusted. XP-G2 flambé…
I used my toaster oven, set to 360 deg F to remove the old LEDs. Worked fine. I could have used it to reflow the new emitters, but I wanted to be able to see them as the solder melted.
I do a lot of electronic repair, so I decided to go ahead and upgrade my soldering station to the hot air rework unit I show above.
As far as I remember Match himself didn’t trust his Vf measurements (whereas his lumen recording seemed pretty accurate and I regularly rely to his charts).
When djozz did his “crash testing” he stated Vf as well and had 3.55V at 3A for an XP-G2. That sounded very reasonable - and is higher than XM-L2 with 3.4V at 3A and much higher than an XM-L, which seems to have a Vf of 3.15-3.20 at 3A. Here is the post of djozz with the graphs for XM-L2 and XP-G2.
