The protection circuit is used for more than lo-voltage cutoff - it also cuts current in the event of a dead-short.
The working current limit is also a PCB variable not mentioned here. There is little use for a PCB that allows no more than a 1.5A current draw, for example, with an XM-L.
Having been self employed for years, I can't forget paying the bills.
I think we have to remember the manufacturer is in this for a profit. There seems to be fewer buyers than builders need to make it worthwhile to bring these "logical" products to market.
When was the last time you went to your job and worked for free?
That is awesome, thanks for the info! Out of curiosity, would that low of a cut off voltage render the battery unsafe afterwards, or does the battery come back up after resting?
Thanks to viffer I'm going to order a couple circuits for protecting 26650s!
I mostly want low voltage cutoff as they'll be a gift...(I'm too paranoid to wait for circuit to kick in)
though, obviously, tripping at too low of a current would be bad. guess it isn't a problem for these. too bad these are from DX...at least her birthday is in May.
anyway - I have 25ft of ebay pvc shrink (black) for doing sub-cs and I'm scrapping that project, so I'll only need a foot or two for myself. I *think* it will fit on 26650s. If anybody wants some, pm me.
No need to solder the minus to the battery i.m.o.
Just put the minus tab between battery and shrinktube.
More than enough mm² contact surface.
However, might any electrolytic phenomenon happen to ruin the fun, I’ll let you all know a.s.a.p.
O, and I solder the plus tab on the plus, no extra teet needed.
All in all some 2.5mm added to the length of the battery.
Insulation for plus tab with one layer of kapton tape.
Also insulated the bottom, in case of cracking the PCB, not possible to short.
Superglued the prot. circuit in place before soldering the plus tab.
I used shrink PVC for 18650 on 14500 batteries, which I do not recommend.
FT has 14500 size shrinktube though.
Bit of a necro post.
But I’ll join in anyway. Seiko protection pcb on aliexpress. I was just searching awhile ago to see how available quality seiko protection was. Also comes in a 20 pack for a lower price each. Battery wire strips are available on ebay.
The protection ICs they use are cheap. If your adding protection get seiko.
I not really a fan of heating the bottom. I try to avoid it. I know some use a high wattage iron & do it very fast before much heat can spread. Might be fine. If soldering I might go for low temp solder & do it on a chilled battery.
Aliexpress/Fasttech = walmart, alibaba/dhgate = SAMS
Walmart is retail=individually wrapped, SAMS is wholesale=bulk lots
same critter…don’t believe for a second that ALL of these places aren’t buying HUGE lots from the wholesalers and just reselling them
Same board but the chips are different. Evva vs. Keeppower NCR18650B Protection
Seiko is regarded to be top quality. The chips often used on cheap protection is of unknown quality. No hard data on their quality. Personally I suspect they are junk compared to seiko.
