Push & hold switch button when the light is on, et voila, your blinkies will appear! :bigsmile:
I wanted to take out all the variables, and see how many amps the star would take hooked directly to 4 cells in parallel. Here is a picture of the star with the 6-XM-L2s.
What I did is remove the star from the light and disconnected it from the driver. I had already upgraded the leads to the star to 16 gauge wire to handle the expected increase in current. I made a 4 cell pack by soldering a copper buss to the postive and negative terminals of the cells. The cells are the purple Samsung 2800 from the laptop pull posted by Siskiyou. I charged them up to 4.18V and connected everything together.
The cell pack
The circuit.
The meter on the left is reading the voltage of the pack. The yellow meter in the middle is measuring the temperature of the star. I placed the thermocouple right up next to one of the LEDs’. The meter to the right is going to measure the current to the star. Because this is a direct drive hookup, I knew that the LEDs would be subject to thermal runaway and wanted to monitor that. It is hard to see the star as in this pic it is edgewise, but you can see the orange clamp that is holding the thermocouple. Here is a picture of that connection. The little silver blob to the right of the LED and under the yellow tab is the thermocouple.
Now a very short video (19 seconds) of direct drive to the star. No driver.
Notice the current goes up and the temperature increases. I only let the star go to 50C as it is not sinked and was rising fast. Anyway about 10A. I believe the limiting factor is the copper traces on the star, probably some resistance there. Here is an angle shot of those traces.
OK, now onto the driver. First thing I did when I opened up this light was replace the original MOSFET with a 70N02. The 70N02 is a low resistance FET. Let’s see how this driver does with that replacement, comparing it to no driver at all, direct drive. In otherwords, will this driver hinder the maximum performance possible? The light is back together, here is a pic of that setup. Weakest link here is the alligator clip connections. The clips are NOS “Mueller” a vintage good quality clip and the banana jacks are also NOS of good quality. The leads are 16 gauge.
Now another very short video of the test.
Once again, about 10A
I think what this shows is that with the simple, and cheap, mods of changing the FET to the 70N02 and using heavier lead wires, this light can become all that it can be. Don’t forget the spring mod. This time when I put it back together I added some thermal grease to the threads of the threaded sink.
In conclusion, We got a GREAT deal on this light! There can be some improvements to the output of this light with a couple of cheap and easy mods. I believe the traces on the star to be the ultimate limiting factor. Personally, I would (did) some simple and cheap mods to improve the output. Total cost: $23.10 (DX US) plus about $1 for the 70N02 and the new lead wires. Of course the spring mods are free.
If someone could figure out how to add copper wires on top of the traces to the LEDs on the star, we could cut down on the resistance there…………
Nice testing. I’ve burned out the traces on three lights that had all the emitters mounted on a single MCPCB. I’m not sure why. Heat?
Good stuff dchomak, makes my wait a bit easyer, thanx! Can you please measure the Amps (original vs modded) in LOW mode?
Very nice testing dchomak!
I have no SRK, nor plans to buy one, but I like seeing mods happening, very good information/pictures/video's :-)
Could always try stripping the solder mask over the traces and run a bead of solder to thicken the traces, then kapton tape the snot out of the top of the star
Are they the typical hi>lo hidden strobe? How bad was the PWM on the lower modes?
Wow…very nice SRK, definitely needs good heatsinking, is the star bonded to the pill or just silicon grease?
I wish my SRK had a pill, all I have is a star that sits on the shelf that was machined out where the threads “should” be…
(once I get the driver up and running right, I might go ahead and do the fill of epoxy behind it to see if that helps…yeah makes it permanent…but this is my first “test” SRK, definitely won’t be my last)
That is a scary thought, yes probably to much current and the trace did an imitation of a fuse. We have to be careful of that.
Too late to get stock readings on this light, good thing I have another coming from DX China. If it is the same exact light I will get the readings. I want to know too!
Spacing is pretty good. I can’t detect any PWM on low. I can hear it.
BTW, the older we get, the longer it takes for our eyes to adjust to changes in light levels. Maybe at my age I have “long persistence” eyes.
Maybe not scrape the whole trace, and not every one. Perhaps just the ones that are a bottle neck and perhaps just an area near the LED. I have some small gauge solid copper wire I can use (telephone wire). If need be that wire can be pounded flat first, insulation and all.
Or maybe connect to the little blob of solder coming out from each LED during the reflow process. That is risky though, may disturb the electrical and or the thermal connection.
Dchomak, first of all I want to thank you for taking the time to post your test findings. However, I disagree with your findings. That 6x XM-L2 MCPCB will pull FAR more than 10A on four good cells. In fact, I would be very surprised to see less than 20A on four good cells with heavy wire to the MCPCB. Mine pulled 13.2A from a single 18650, with the stock skinny wires, over 10A from a single IMR 18350. I am guessing that with 18AWG wire it will do 16A+ from a single 18650.
Something in your test setup is adding a lot of resistance.
If it pops may end up scraping off the solder mask then adding solder to the traces on the MCPCB, if that doesn't work I will jumper the traces with wires.
RMM, is that current draw measured with direct drive, stock driver, or with the MOSFET swap?
I was very aware of how resistance in the circuit could impact the results, that is why I set it up so as to try and eliminate any possible points of resistance. As you know, it only takes one bad connection to cause a problem.
If that is the case, then it could be the alligator clips, banana jacks or even the cells themselves. Voltage at the pack dropped 0.2V after the 10A draw, so the internal resistance of the 4 pack would be .02 ohm or 20 milliohm. Times that by 4 and you get 80 milliohm per cell. Is that about to be expected for that cell?
I am pretty sure that XM-L2s will draw less than an XM-L with 18650s in direct drive. But you are right in expecting much more, so was I. That is why I immediately suspected the traces on the MCPCB.
The light is back together, I will try a test later with nothing but solder joints at ALL connections, even the meter. With the driver in place if the current goes up, then we know.
Actually, the current draw in the video is slightly higher WITH the driver than WITHOUT. That means something is amiss here. This is a case where if I am wrong about the MCPCB, it would be GOOD news. I would be glad to be wrong about that.
Direct drive to the MCPCB with the stock skinny wires and a single cell.
The 0.2v drop isn't much at all, actually. Especially since those are 4.3v cells which unless I misunderstood you've only charged to 4.2v. Even so, you should be seeing much higher number with that, especially with 16 AWG wires running to the MCPCB. Even with those cells charged to 4.2v I would expect 18A+ out of of that setup.
I have my test leads (a pair of 18 AWG on each plug, not sure if that's still as much as a single 12 AWG but it's enough) soldered directly to the jacks of my DMM (also a red HFT like yours.) I noticed that at 6-7A my banana plugs would start to get pretty warm, so I got rid of them. The only reason I don't try and measure more than one cell is that I am pretty sure it will pop my DMM, I ruined one once trying to measure 4 20Rs into 3 XM-L2s...I need to get a 30A ammeter for these big multi-cell parallel lights.
P.S. (edit) PLEASE don't take anything I've said as an insult. I know that sometimes on the forum it may come across that way, I really don't mean it to. We are all here to learn from each other and I appreciate you posting your experiences.
RMM, I wasn’t insulted at all. Like I said, I am hoping I am wrong.
Just to show you how things go, I am revisiting this post because I just realized my math was wrong. The cells dropped 0.26V, not 0.20. So the internal resistance of the cells comes out to 104 miliohms.
You know it’s funny, that trick about soldering the test leads directly to inside of the meter that you mention, you learned from me. I hooked a bunch of meters into the same circuit.. I learned it from Pulsar13 . I NEVER GOT AROUND TO DOING IT. Shame on me.
If I were to blow a meter, so what? My wife just so happens to be picking up another FREE one at HF tonight on her way home from work.
Hows that for a loving wife.
RMM, I wasn’t insulted at all. Like I said, I am hoping I am wrong. Just to show you how things go, I am revisiting this post because I just realized my math was wrong. The cells dropped 0.26V, not 0.20. So the internal resistance of the cells comes out to 104 miliohms. You know it’s funny, that trick about soldering the test leads directly to inside of the meter that you mention, you learned from me. I hooked a bunch of meters into the same circuit.. I learned it from Pulsar13 . I NEVER GOT AROUND TO DOING IT. Shame on me. If I were to blow a meter, so what? My wife just so happens to be picking up another FREE one at HF tonight on her way home from work. Hows that for a loving wife.
Right on! (I also have a few extras laying around.)
Nice test dchomak. I'm sure you addressed this and I just missed it. Isn't the limit on that HF DMM 10A?
Isn’t the limit on that HF DMM 10A?
Yes, but it will do more than that for short periods of time, I've done 13-14A with it. My first one didn't handle ~20A very well though.
Nice test dchomak. I’m sure you addressed this and I just missed it. Isn’t the limit on that HF DMM 10A?
RMM is right, little known fact, it will measure up to 20A but the hardware can’t take the current.
RMM, preliminary results look like you are right about my connections. I am in the process of charging that pack up right now. I will update shortly
Back to the HF meter measuring up to 20A.
Notice all the other scales on the meter start with the number 2. There is a reason for that.
When this meter measures 10A, what it is really measuring is the voltage drop across the 0.01 ohm shunt resistor. Using Ohms law that would be 0.1V. To measure 20A it would be measuring 0.2V, and we know the meter can measure THAT.
It’s using that scale when in 10Amp mode.
Now the reason for all the scales starting with the number 2, it’s called “Benford’s Law”. Here is the Wikipedia article, it is REALLY interesting stuff. Employers can use it to spot fake expense receipts!
OK, the cells are charged up to 4.20V and the head of the light with the driver in place is ready to go. This time all connections are soldered including the connections to the meter. The leads are 14 gauge and are soldered directly to the banana jacks inside. Also the wires to the cell pack are soldered and the connections to the driver are soldered. There are now NO banana plugs or alligator clips to introduce resistance because of less than perfect connections.
Cells sitting at 4.20V and the light is not yet turned on, 0.0A.
Now on high, 13.75A, 2.3A per emitter.
Wow that is a lot of juice! So let me see if I got this right:
$23 Flashlight
$ 1 MOSFET
$ 5 Batteries
$29… Now that is one Value light! Wonder how many lumens/$?
