OK, the cells are charged up to 4.20V and the head of the light with the driver in place is ready to go. This time all connections are soldered including the connections to the meter. The leads are 14 gauge and are soldered directly to the banana jacks inside. Also the wires to the cell pack are soldered and the connections to the driver are soldered. There are now NO banana plugs or alligator clips to introduce resistance because of less than perfect connections.
Cells sitting at 4.20V and the light is not yet turned on, 0.0A.
Now on high, 13.75A, 2.3A per emitter.
Wow that is a lot of juice! So let me see if I got this right:
$23 Flashlight
$ 1 MOSFET
$ 5 Batteries
$29… Now that is one Value light! Wonder how many lumens/$?
**Received mine today. Its my first fatty If my multimeter is correct, it draws 7A on high and 2.7A on “low” from 4 freshly charged panasonic laptop pulls. The quality, look and feel is superb for the price.
Thanks for the info RMM and dchomak. So you take your readings before the shunt starts getting too hot. Makes sense.
dchomak, Great info on the resistor, voltage, and Benford's law. Looking forward to reading that Wiki you linked. Thanks again.
Some here may wonder about the $5 Siskiyou is referring to. I mean how can 4 - Samsung 2800 mAh be only $5? In my case, and others, I have lucked out every step of the way on this one! The battery deal referred to is a NOS $10 laptop battery pack deal that he posted about here on BLF a couple of months ago. 8 Samsungs, new and in perfect condition. Turns out it is the perfect companion for this light, 2 sets of 4 cells. One in the light and the other set charged up ready to go. The deal has expired now but here is the link.
Hi all, I’ve been lurking here a while and taking advantage of Deal Alerts and thought I’d finally join and contribute one of my own. Bought this pack the other day and inside were 8 of these purple Samsung batteries. On the outside of my pack was a “manufactured oct. 2010” date stamp. Unfortunately after reading HJK’s review it sounds like I won’t get the full 2800mah out of them with my charger, but at $10/pack or $1.25/cell it still seems like a great deal. The sale ends in one day per the…
Another benefit of these cells is that they are meant to be “over charged” to 4.3V. I won’t normally be using them that way and neither will most others that picked up on this deal. But I thought I might as well go for it and see what they will push through the light at 4.3V, so I charged them up.
On high, 15.02A
On “low”
Notice that 1/10th of a volt more pushes another 1.25 Amps. The open circuit voltage is not what does that but rather the voltage while under load. I’m sure IMR’s would do even better, as they will not sag as much under load. I have some, but so far I have resisted trying them out in this light. My biggest fear is blowing the traces on the MCPCB
Yes, the low resistance cells will do significantly more than that. A single VTC4 or 20R will almost allow amps than four of those cells, for a little while at least. Four VTC4/VTC5/20R/25R will do around 20A into three XM-L2s, I am guessing that with 6 XM-L2s 25A isn't out of the question with these cells, maybe even 30A.
The nice thing is that you can use higher resistance cells to limit current. The NCR18650B is a good example of this, great capacity but it will only do around 4A maximum direct drive.
What are the odds of ever finding some of these VTC4/VTC5/20R/25R in a laptop pull? That would be sweet! Didn't know they make that much difference in our flashlights versus they panny 3400!
Just wondering if we should make a new thread for modding this specific SRK?
What are the odds of ever finding some of these VTC4/VTC5/20R/25R in a laptop pull? That would be sweet! Didn’t know they make that much difference in our flashlights versus they panny 3400!
Zero. They are not laptop cells, high drain cells are used in other applications such as power tool battery packs.
Good idea! I ordered a Mosfet and low resistance silicone wires from Mtnelectronics.com to boost this new friend!
I don’t know if there is a better thread for this but I just wanted to let you know that DX finally shipped my order of three pairs of protected Sanyos (sku 121447) they had on sale at the same time as the Skyray of the OP.
They are back on sale but now at $11.99. They exchanged the pictures, too.
I just finished the mod of dchomak with the low resistant wires & mosfet I got from RMM (thanks guys!). Also did a tail spring mod with soldering lytze and put more thermal compound between star & pill.
As dchomak already mentioned, the driver is glued in the head and I also had to pound on the driver from the other side to disassemble. When desoldering the wires, I notice the red wire was connected to the L- on the driver. I didn’t remember whether it was connected to the + or - pole of the LED star, so I soldered the new wires + to + (red) and - to - (minus). The flashlight didn’t give a kick so I crossed the wires.
I tried to screw back the battery compartment and the SRK gave an intense bright hot flash so I thought I blew the LEDs to heaven J). In a startle response the batteries flew around the room :~ Didn’t smell bad though, so I picked up the batteries and screwed it on again.
The light started shining, so apparently it was default on. Well, in fact it was SHINING!! My goodness, this is a performance boost, I really felt a powerful hot beam shining on my hands. The body got also quite hot quickly so there must be a lot more Amps pumping around.
In my opinion, this DX SRK is a real BLF champion. Cheap, quite easy to mod, good quality and a powerful lumen king. Highly recommended!
i ripped one of the traces trying to replace the mosfet. Anyone know of a replacement driver ?
Still haven't received mine yet.
I had ordered 2, 1 each from DX and DX-US.
DX-US shipped on 4/1 and I received it 4/12
DX shipped on 4/2 and I have not yet received it as of 4/26.
I am looking forward to it so I can measure the “before” performance.
DX is now asking $36.65 for this light, what a nice deal we got.
I was reading about warrior: The King is dead? Long live the Warrior!! and I really liked some features like ramping brightnes and lock out. My SRK 6x xml2 has very high “low” around 40-50% of max current (a real low of around 20% would be more usefull for me at least). When I was trying lock out feature on SRK (btw it does work with just a small twist) I found out if I set it to low and twist it just before it looses contact, I am able to get very low brightnes (much below 100 lumen).
i think you just creating high resistance in the threads - maybe it warms up and sizzles there…
If you can replace the FET I’m fairly confident that you can repair the trace. A jumper wire will be lower resistance than the trace is anyway.
Here are pics of the tear down. With the tail cap off. First time I have seen one with all 4 screws installed.So I had to go at it from the other direction. After unscrewing the bezel, I used a sock (for the feet) over my hand to unsrew the reflector. I was very happy to see this, as other cheap SRK clones did not include this. This provides a good thermal path to the body of the light. Once I was able to get behind the reflector, I was able to pound out the driver from the back side. It took quite a lot of force to break it loose. The leads to the star are 24 gauge. !
got mine today...
Compared to my Supfire M6 (300 lux ceiling bounce, versus 220 of this Skyray King), I want to get this thing apart.
How can you get the reflector off, when the white led centering rings are still installed?
Well DX lied and is playing games again. This is twice I’ve ordered the SRK at a low price from DX and they then wait a while, then claim its out of stock, but have another light listed at a higher price that looks like the same thing. Of course the new listing requires more money before they ship. DX is a really crappy scammy site! Randomly some people actually get the light to increase interest, while others get the scam setup message for more money to ship out I guess.
