I just bought 3 of the warm versions for $2.89/each shipped here
Thanks, Sirius9!
That's actually the same seller I ordered mine through... Only mine was $2.93/each, which is the currently listed price. You saved .04 each!
Plus I bought the last 3 warm versions that he had in stock
I am glad that many of you are satisfied with Mini, I can’t wait until the version with photodiode gets here and also few of warm white Mini’s
A version with photodiode?
I made a video with USB Charger Doctor connected to show current:
Photosensitive version on ebay.
Thanks for the current consumption video, so, we can power this thing in moonlight mode forever since it draws 0.00A :bigsmile: (just joking pity USB doctor does not do microamps).
P.S. I ordered USB Charger Doctor too, from DX for $3.78
:bigsmile:
It is more like 280mA on high, 2.2mA on lowest (here autoranging meter would be nice):
High:
The LEDs seem to be Samsung LM561B.
I concur. page 19 shows the same black dot on the led. appears to be the 5000k version.
Hi Chloe.
Couly you tell me something about the warm tint? Is it good looking or awful yellow? PWM is visible?
It is not a terrible warm tint. Maybe a bit warmer than I’d like though. I could not tell any PWM with my camera or moving the light around.
Here next to a Nichia 119, 3500K (right), the Nichia looks more neutral, though slightly green, where the warm white Mini is slightly pink:
And for extreme contrast, next to cool white XM-L not very flattering to either tint.
I received today another CW, WW and WW with photodiode. I like the WW version, its nice but I am not too happy with the self adjusting version, It flickers a lot
Maybe the photodiode is too sensitive? Try to put some light diffuser on it.
Thanks for help Chloe
I presume that also, will try the trick with difuser, thanks, if it works I may try to use white nail polish :bigsmile:
In the meantime, you can wave the mouse over this image :p
Is the 3 LED version with photo diode noticibly less bright on full brightness than the 6 LED version (without photo diode)?
Does the 3 LED one have PWM or is it the flashlight causing the flickering?
Yes, about 50% J) Just joking actually, it appears they are about the same intensity if 3 LED is not even stronger, yes you read that right. Can’t test them both in the same time obviously but 3 LED version apperas “a hair” stronger.
3 LED Mini is flickering It seem that the led intensity control depending on a photodiode input is straight forward, IF -> THEN, without any averaging and when the ambient light is on some margin LED intensity “jumps” up-down.
Did you try to adjust the sensitivity:
Does it flickers even when on full brightness?
Be careful adjusting those pots, they can be delicate.
