No doubt FT is the best deal around on all 3 new models. But if you want a 3C tint though, RIC has it, though you got to pay bout $9 more , plus shipping.
No, NW (XM-L2 T6 3C) is also available from Banggood. At the moment they have a promotioncoupon and the prices are better as the FT prices:
You can choose CW (XM-L2 U2 1A) and NW (XM-L2 T6 C3). I bought one of the SC02 with NW.
SC01, 1*AA(14500) coupon:bgf164 $14.19
SC02, 1*18650 coupon:bgf170 $14.9
SC03 1*CR123A (16340) coupon:bgf171 $14.19
Oh, cool! Forgot bout BG..
I will not buy another flashlight no matter how pretty it is, I will not.
On the other hand, itâs true that I need more AAs, and this SC01 looks great, but I wonât buy it. I will not.
Damn, this thread⌠I just bought it. :bigsmile:
I just bought neutral SC02 with no good reason (because I already have small 18650 light - Nitecore EC2).
one of us, one of us.
Itâs not the first time - I have about 15 flashlights. I use 3 regularly.
Got mine inâŚfrom BG payed $19.99
Also got a shipment from FTâŚhad 5 of these in them
https://www.fasttech.com/p/1574902
For poops and giggles I took my Ganzo multi-tool (also from FT) and unscrewed the front bezel ring, dropped the reflector and lens and o-ring, held it next to the TIR in the housing, wouldnât you know it almost EXACTLY the same sizeâŚgently folded back little tabs holding the plastic TIR insert, dropped the TIR out, lined up the square in the bottom of the holder on the emitter square on the star (which I am going to be reflowing to a 16mm copper sinkpad shortly), then using a small screwdriver tool that is hollow in the end pushed it down where the reflector was sitting and centering it on the XM-L2 on the star, then dropped in the plastic insert TIR and clicked it in the holder, put in the o-ring and then the lens (it was about 1/32â too short, so the lens made it exactly the same size. Tightened down the bezel ringâŚand voilaâŚinstant dropin TIR.
Almost no hotspot, nice wide flood and still very bright even though you loose some light in a TIR.
Just wanted to give you guys a heads up on what seems to be an almost perfect drop in TIR for the SC01.
Just walked around in the back yard, tons of flood and still good out to about 40-50 yards with a 14500, a AA is a little bit dimmer but just like the SK68 the boost mode is always less bright as the linear regulator mode.
Awesome little light
I have to wonder if one of the xpg tripples will fit⌠and what sort of currents can be squeezed out of the driver.
Isnât the light floody enough already?
YeahâŚ.I just did it to try it out
I kinda like it with the TIR, maybe because I didnât use it but 4 minutes with the reflectorâŚhmmm
Damn you all, have been watching this thread and holding back⌠I couldnât take it any longer âŚ. ordered the SC03âŚ
Good Day,
Could someone that has the Solarstorm SC02, Please let me know if a Panasonic NCR18650B 3400mAh Protected battery will fit in it?
(Fasttech says that maximum battery length is 67mm, But can we trust what they say? )
Otherwise Please let me know which battery You use in the Solarstorm SC02.
Thank You Very Much,
Roberta 0:)
I have one on the way, ill get some pictures and measurements when it gets here.
Good Day Serifus,
Greatly Appreciated :exmark:
Roberta 0:)
Ok, has anyone successfully disassembled a SC01? What is up with the extra - wire? I got mine apart far enough to swap out the reflector for a TIR but couldnât get the pill out (pressed in? because screwing it out ainât happening)
Im going to hazzard a guess that the 3rd wire is a ground for the isolated central heat pad, ill see how far i can get one of mine apart when they get here.
The star is held down by two small hex screwsâŚI didnât try to remove mine
Well, my tracking updated and they should be here in the next few days.
Post #67 shows the exposed star with the 3 wires. Also, couldn't get mine apart - got the bezel off though.
