better yet, get some PIC guys to get the stuff from China…see if they can get the firmware and either reproduce it or make custom firmware with better modes and better PWM frequencies
Take what they have and make em better
Still way early in the learning stages. I was looking at your Ultimate Flashlight Code post that you made in your blog back in October 2012. That the PIC12F1822 data sheet is interesting. Compared the Attiny13A data sheet, it looks more attractive to my untrained eyes. Has twice the RAM and 4 times the EPROM memory. Standby power usage is super low (20nA vs 24uA).
Would you still use the PIC12F1822 MCU if you were to update your D10 or EX11?
Wow man, I would love to have an SRK like this! Amazing work! Need to get some chinese manufacturer to make this, and call it the SRK - RGBWUV Edition!
And would be cool with a 7 XM-L2 SRK, make 3 LED's white, then the other 4 LED's red, green, blue, and UV!
Edit: Is it possible to sell me one of these drivers already made for the SRK?
Hmmm, actually I probaby would pay $60 for a flashlight with this kind of mod. Would be an amazing flashlight with dedicated XP-E's in red, blue, green, and UV, then have 3 XM-L2 U2 1D, that would be amazing! Ya, for $60 I would definitely get it!
Yes, the 12F1822 is the perfect choice for writing in C on a tiny 8-pin part. I haven’t used them much in my mods simply because my work throws away lower-level parts (12F617) by the boatload, so I use those since I hate to see them go to landfill. If you pursue a project with the 12F1822 we would be able to port pieces of my MELD code right over to it (if that’s the kind of functionality you’re looking for)
Thank you again tterev3. I purchased the flasher you recommended above. So I will be flashing and that MCU you discussed is very affordable. I think I will first attempt to adapt my favorite Attiny13a FW to the 12F1822 first. I have to study to the 12F1822 datasheet more so that I can figure out what adjustments I would need to make to the code.
MELD looks like an incredible program. It just has so much more functionality that I feel I should tackle at this time. I really like your concept of having all those colors and UV in one light. I have separate, green, red and UV lights. It would be really cool to have all that available in one light. It's just too much for me at the moment. I need baby steps.
Thanks again for your very gracious sharing of your knowledge and efforts.
Here's an example program I put together for the 1822. It's a very simple flashlight with 3 brightnesses and a randomized strobe that changes modes on power cycle. This should help you get started with the 1822:
//v0 4/21/2014 by Everett
//initial version
//simple flashlight controller. mode change on power cycle
if(TMR0IF){ //fires at 1kHz
TMR0IF=0;
if(strobe_timer){strobe_timer--;} //count down milliseconds
void main(void)
configure(); //set up hardware peripherals
delayms(15); //short delay to avoid power glitches incrementing mode
if(key==12345){ //RAM retention trick to detect quick power cycles
mode++; //go to next mode
if(mode>max_mode){mode=0;}
else{ //long power loss. default to first mode
mode=default_mode;
key=12345;
switch(mode){ //initialize current mode
default:
case max:
CCPR1L=255;
break;
case med:
CCPR1L=25;
break;
case low:
CCPR1L=1;
break;
case strobe:
strobe_timer=0;
on_off=0;
CCPR1L=0;
break;
GIE=1; //turn on interrupts
while(1){
if(mode==strobe){ //no other modes need active tasks while running
if(strobe_timer==0){ //timer ran out
on_off=~on_off; //flip it
if(on_off){
CCPR1L=255;
strobe_timer=on_time; //set on time
else{
CCPR1L=0;
strobe_position++;
strobe_timer=stun_rate_lookup(strobe_position); //set off time
} //set output
Thank you. Very good idea to start with code that works since someone new to PIC programing/flashing (like me) will probably be dealing with other first time issues. One less potential complication. Looks like the code is for a normal clickie type switch (on/off, half click to interrupt power). Is that correct?
Received my programmer today. Excited to start going down this path, but I will have to be patient as I have quite a few demands for my time right now, plus the Scratch Build Contest.
Thanks for the write up. In my brief experimentation with PIC, I found MPLAB-8 much clearer than MPLAB-X, and that was coming into it with ZERO experience. I might have to start using my PICKit 3 again...
