What! No AAA?
I can only find one at the moment, the A1 (which I wrongly put under AA prior to your question).
Know of any others?
Thank you! I added more to the list from cnqualitygoods.
Thanks for the suggestions Pregulla! Those look like great lights, however the list is for hosts only without any pre-installed LEDs and components.
However I’m sure people can still purchases these (as you have linked) and dismantle.
I don’t know if this list of suppliers will be of any use to your search but it might contain some vendors you haven’t looked at yet.
What a useful resource for DIYers! Thank you!
This is an awesome list of a lot of hosts currently available, so thx
Some hosts are to find at several vendors, sometimes even cheaper. But they can be googled easily, so this list is a wonderful start to get the overview.
I didn’t know the xintd x3 was available as host. Nice find.
HQ
Brilliant, thanks for compiling this
I notice you have the X-power 18650 host listed as “generic copy of S6”, don’t let that confuse you, I actually prefer the x-power to the convoy. Machining is perfect (not that there are issues with the convoy), ano is perfect, threads are perfect, at almost 1/2 off the convoy it [the x-power] is the better light.
I’ve only owned one, and one S6 so maybe my samples were exceptional (good for the x-power and nothing-special for the convoy) so take that into consideration but IMO the x-power is the better host.
Thank you cereal_killer, I have made a note next to the X-power now.
These lists just prove BLF will give you OCD
Nice list!
OEM D4 is the generic Convoy M1.
The OEM Zooming mentioned in OP is not similar to Convoy M1.
Thanks RaceR86. Sometimes it’s hard to tell which is which and I forget which ones I’ve already seen and listed.
Thank you for pointing that out! I’ve changed it on the OP.
Could you add which ones are P60 compatible? (Solarforce L2 and L2M are the oens I know)
Hi ozlight, I’ve updated a few of the Ultrafire lights to show whether they are P60 compatible. Hope it helps!
