Recommend me a dual hi power USB car charger, need it to charge 2 smartphones
3 posts / 0 new
AlexGT
AlexGT's picture
Last seen: 3 days 8 hours ago
Can anyone recommend me a good dual USB car charger, I need it to be able to charge a note 3 and an S4 at the same time and at full power, so I need at least 2A per port.
What do you all suggest? Thanks!
Edited by: AlexGT on 04/19/2014 - 22:32
TexasToasted
TexasToasted's picture
Last seen: 6 days 8 hours ago
The Samsung charger for the Note 3 runs a slightly higher voltage, 5.33V on mine. That extra .3V does make a difference. Samsung also applies a sensing voltage to the data pins on the USB port out of the charger that the phone/tablet reads to know when it’s connected to a proper Samsung charger capable of supplying higher current. Apple dose the same thing, but uses a different voltage.
To charge a Note 3, or a Samsung tablet, at it’s fastest rate requires a charger with the proper Samsung voltage on the data leads as well as high current capability.
I have not seen one for the car, but here is one for the house with a dedicated Samsung port that does have the required sense voltage on the data leads.
Edit- here’s good info about the Samsung sense voltage.
AlexGT
AlexGT's picture
Thanks for the info, I found these ones on amazon but not sure how good they are, anyone have one of them and can comment?
http://www.amazon.com/PowerGen-4-2Amps-charger-Designed-Android/dp/B0088...
and
http://www.amazon.com/Anker®-Dual-Port-Charger-PowerIQ-Technology/dp/B00B8M4IMK/ref=zg_bs_2407770011_15
