Opus BT-C3100 V2.0 "Dreamcharger" GROUP BUY Now @ $ 36. New coupon code - tatasal -(to close July 15) NOW CLOSED
1447 posts / 0 new
tatasal
Last seen: 11 min 30 sec ago
leaftye wrote:
tatasal wrote:
ANNOUNCEMENT: Gearbest, the dealer of the subject charger (the BT-C3100) in this groub buy, has contacted Opus Instrument, the manufacturer, and bought a supposedly ‘improved’ version of the power supply. Gearbest has contacted HKJ and will send the new power supply for a quick review. Whatever the result of the new power supply’s performance be, Gearbest is committed in this endeavor and will still sell at the Group Buy price of $41, to those who are in the list of participants but still want to proceed to buy, even in the event there will be less than the minimum of 50 commitments.
Do that mean the group buy won’t start & end before HKJ has tested it?  I’m in if so.
Yes.
Tomorrow Dora of Gearbest is expecting to receive the new power supply. Then it will be sent to HKJ for a quick review.
HKJ
HKJ's picture
Last seen: 2 hours 4 min ago
tatasal wrote:
Yes. Tomorrow Dora of Gearbest is expecting to receive the new power supply. Then it will be sent to HKJ for a quick review.
I hope it is a complete charger, not only the power supply.
tatasal
PM sent. Thanks
Edit: HKJ no longer has the version that he tested/reviewed.
tatasal
This post is from Henry Xu, the chief engineer of the BT-C3100: Reply concerning HKJ’s conclusion
(copy/pasted for his post #145 http://budgetlightforum.com/node/28599?page=4#new
Post # 145
1. The charger is oscillating and stops the charging a bit too premature
This has been solved by firmware update: charger will make no current increase back in the CV stage. So no oscillating at all circumstances.
2.The “resting”/overheating periods during 2A charging or 4 × 1A discharge
2A charging is supposed to be used for high capacity Li-ion batteries, we should mention this in user manual that charging with ni-mh AA batteries with 2A charging current is not appropriate. Since 1A discharge current for 4 pcs li-ion batteries will generate a lot heat, and the fan exhausting speed is not fast enough.So it can lead to thermo-protection kicked in, which this safety mechanism is designed for. So I hope it is acceptable. If only two batteries is discharged at 1A speed, it should be no problem.
3. Power spikes from the power supply
We noticed for 9A peak current with very little period time of less than 10ms. we improved this problem by adding a larger enough filtering capacitor and its peak current now is reduced to 7A. The problem is not 100% solved, however it is improving the power supply quality significantly.
4. Uses trickle charging for NiMH when cell is fully charged
I think trickle charging current for nimh is necessary. And we believe this is a good feature of this charger. We have no plan to take this trickle charging away for nimh batteries. For li-ion batteries, there is no trickle charge current.
Boro
Last seen: 1 day 7 hours ago
I would like to purchase one ( 1 ) charger.
Thank you.
danjayh
Last seen: 11 months 3 weeks ago
Can anyone comment on how this deal varies from the version listed as a BC3100 in this previous deal for $45? Presumably they either will both have / not have the oscillation problems (although since it results only in minor li-ion undercharging, it’s probably not a big deal anyway)?: http://budgetlightforum.com/node/25886
kuoh
Last seen: 1 week 1 day ago
Well, I guess I’m in for one as well, since I really prefer proper slots over the mess of wires & magnets with a hobby charger. If I’m understanding this right, it looks like they addressed the power spike issue within the charger itself rather than using a higher current power supply. I wonder if we can add an even bigger capacitor to “improve” it more? What will it do to the life expectancy of the power supply by drawing over twice the rated current, even over such short time periods?
KuoH
tatasal wrote:
3. Power spikes from the power supply We noticed for 9A peak current with very little period time of less than 10ms. we improved this problem by adding a larger enough filtering capacitor and its peak current now is reduced to 7A. The problem is not 100% solved, however it is improving the power supply quality significantly.
danjayh
In for 1 unit iff HKJ is able to confirm that issues are resolved.
EDIT – Emailed Dora with the above…
cnlson
Last seen: 10 months 15 hours ago
In for 1 unit and emailed to Dora.
actually joined up to participate.
moT
moT's picture
Last seen: 3 years 2 months ago
welcome to BLF
ALL YOUR LUMEN ARE BELONG TO US.
danjayh
I cross-posted this deal over at SlickDeals. If any of you are also SD members, go thumbs up it & help answer people’s questions and maybe we can get a few more towards the 50 unit goal.
http://slickdeals.net/f/6874960-opus-bt-c3100-dream-charger-analyzer-for...
XChesser
Last seen: 7 years 1 week ago
Hi BLF,
Is this group buy for US version only, or EU will be down to $41 either?
http://www.gearbest.com/chargers-batteries/pp_24924.html
tatasal
XChesser wrote:
Hi BLF,
Opus BT-C3100 LI-ion NiCd NiMh LCD Smart Intelligent Battery Charger with EU Adapter – Black
I think it comes with an EU like in most photos, with a US adapter.
jealous57
XChesser wrote:
Hi BLF,
Taken from post #49
arekm wrote:
Damn!
I’m in EU/PL and the group buy is about version with “US plug” Sad
That means that I cannot buy it. Somehow didn’t notice this earlier.
EDIT:
Dora wrote in email:
Quote:
Hi dear,
Please don’t worry for the power supply plug, we have both two plugs, US and EU, for the group buy, you can choose as you like Smile
Regards,
Dora
XChesser
Link in the title goes to “Opus BT-C3100 LI-ion NiCd NiMh LCD Smart Intelligent Battery Charger with US Adapter – Black”
Gearbest has EU version either but it is more expensive now ($56.99 vs. $59.14), and it’s unclear whether special price is coming for both versions of just US.
:~ Sorry for misunderstanding. You mean it is EU or US?
XChesser
jealous57, thanks. Now it’s clear Smile
I am in. 1 pc.
37. XChesser
38.
39.
40.
tatasal
Same Group Buy for both configurations
lionheart_2281
lionheart_2281's picture
Last seen: 9 hours 12 min ago
If HKJ gives this the nod (after his second review) over the i4 I will one
cnlson
done and done
tatasal
Thanks
Electroman187
Last seen: 3 days 9 hours ago
I’ll take one if HKJ can confirm the fixes. Emailed Dora.
kuoh
That would be somewhat disappointing, as those adapters usually make the plugs huge and are sometimes loose fitting.
KuoH
gbuyer
Last seen: 7 years 3 months ago
I’m in for 1
Icon
Last seen: 2 years 4 months ago
If the problem is solved, I am also in for 1. Will wait on HKJ to test.
Henry Xu
Henry Xu's picture
Last seen: 6 years 5 months ago
The improved version will show 2.0 after power up for 2 second and then make full segment display turned on. This is the way to tell the difference between HKJ’s first reviewed version which has no version number displayed after power up. In future, if we make any improvement, we will have this version number updated reflecting the change.
tatasal
Thanks for the clarification, Henry.
Edit: Henry Xu is the chief engineer of Opus Instrument, the maker of this charger
Lothar
Lothar's picture
Last seen: 1 week 6 days ago
Same here Smile
Current Collection:
BLF: BLF-GT90, BLF-GT70 (CW Sliced), BLF GTmini, BLF-LT1;
BTU: Shocker (3 x SST-40 @ 8A)
Solarforce: L2P (XM-L2 U3 @ 4A), MPP-1 (XP-L HI @ 6A), MPP-3 (3 x XM-L2 U2 @ 12A), M6 (Nichia 319A @ 6A), M8 (XHP-50.2 @ 9A), 9x (9 x XM-L2 U2 @ 2A)
Coming Soon: Lumintop: BLF-GT4;
banker
Last seen: 7 months 4 weeks ago
I am also in for 1 piece (EU version)
banker
Ejected Filament
Ejected Filament's picture
Last seen: 8 months 3 days ago
Thanks for taking the time to reply to us personally, that speaks volumes about you and the business you represent, most appreciated.
But I have to ask, so with the current fist and second version, unless sellers switch them on and then inform us, we wont know until be buy one and switch it on ourselves if its the revision model? IN essence a lucky dip?
On that, did you read HKJs review of the item yourself or just the highlights and then responded to those?
tatasal
Please read post # 64, just in case you have not.
