His Sky Ray is 17790. My SR is 16680. That's a 7% diff. Let normalise our lux meter readings. (due to meter differences, distance differences etc)
My STL-V6 is 46k. So it would translate to be 1.07*46 = 49.2k.
His Olight M3X is 58k and draws 1.33A and dumps 2.93A to the XM-L. Same as mine 1.32A. Driver could be more efficient due to better components, who knows. Not too bad!
To add here, the 7% variation is well within the Xm-l bin performance variation. So, i might have a very good sample and yours might not be that good. Though, hope this is not the case here!
Also, my lux measurements are taken@3meters, they are just converted back to 1M.
What is the lux meter you are using?
I am waiting too for the same Fandyfire,(dx slow dispatch-delivery times) so i will make a direct comparison against M3X with current measurements on the led and on the same batteries!
Ergotelis, you seem to be always online and capture whatever is being said about you! Can't escape!
Yep, well within the lumen variations within the same bin as specced by Cree, seriously you wouldn't know what Fandyfire/Chinese OEM used, for all you know they just pick the T5 but cool white. Cheap....i mean this is a 46 bucks shipped light with a reflector that is good.
Also M3X could have used a 98% glass. I am sure this is a 92-94% glass. Shucks no pretty UCL lens for this 59mm size!
I am using the under-reading DX meter. LOL!
Also have to factor in driver efficiencies, components....all variations here and there. And also temperature differences, easily another 5%. It is 30 deg C now at night!
I have the sky ray version coming on the slow boat. I was hoping it would clearly out perform the solar force MPP-1. But from your comments it seems about the same as the MPP-1. If you have any beam shots of the two please post.
Interesting, at longer ranges like > 100m, it seems that visually the MPP-1 is casting a slightly brighter spot on a 100% white surface, even though at my 8m measurement range both are around the same. I guess for such tight beams, you'd need at least 20m measurements. In 2 weeks there will be a meetup with some flashaholics and we'll be doing 50m measurements, but i'll be measuring the HIDs and my friend's Polarion PH40. 50m measurements are great but are tiring. Short-arcs are recommended to do 100-200m range!
I'm sorry but distant beamshots on buildings = very time consuming setup of cam/tripod and insert CF card, upload etc., you'd just have to take my word for it.
You will find that the Fandyfire has a much more useful beam, with just a wee bit less throw on distant objects that are near the fringe line of throw, eg 1 lux @ target. No replacement for lumens.
It has 2 groups of modes, a 3 mode and a 5 mode. How it does this is that the head takes -ve from both the body tube as well as from the top of the tube. The driver has a ring of contact which sense the top part of the ring. If just unscrewed a bit (the top part of the tube) the driver ring loses contact and changes into another mode. Cool.
150mm super shorty mode, with 2 x 18350 IMRs inside. Measurement 1.35A, so the IMRs do not really sag. This is probably the shortest non-custom thrower with the highest lumen around. As you can see, the Ultrafire has HA and the Fandyfire head has no HA. No issue, they feel the same, such is the quality. It is no Surefire, but not sure what would you wanna complain for 46 bucks shipped. So it can run 2 x 18350 super shorty, 2 x 18500 shorty and 2 x 18650 normal.
BTW, Dereelight DBS V3 tube and tailcap also fits, but gotta take out the clip.
We have the same problem with heat here,in Crete(Greece) we have 30-35 C ! :S
When mine comes, i will be comparing it directly against! I will test some technical features, such as swapping the lenses/reflectors and measuring led currents. Also, i might test the led too, might swap a good U2 bin from cutter!
Im not sure how this works with 2x 18350 IMR's but i just tried a MF XML 2.8A drop-in a Ultrafire WF-501A and i couldn't get my 18350 IMR single cell to push past 2.4A's.
With yours being in series id think it wouldn't be any higher unless your using a higher quality IMR than i am. Mine is from bestinone.net and 800mAh.
I put my R5 back in thats running at 1.8A and cute as a tiny bug but as powerfull as lights many times its size.
EDIT- Nevermind, I see its only needing 1.4A's with the regulation your light has. But doesnt that defeat the purpose of an IMR as you could get the same size with 1x18650 and have much longer run time with the same amps?
Andi, I suppose the C8 could fit. But the UF-980L does not fit.
We have a very narrow diurnal range here, even Bangkok may dip to 19 deg C in Dec which is cold by our standards. We rarely go below 26 deg C unless there is very heavy thunderstorms say for more than 3hours here and even with that in Dec it gets to maybe 23 minimum. But it does not get very hot here also, the hottest days are 34....36 on very rare occasions maybe two or three days a year.
Good to hear that you will be able to test more. Looking forward! I hope you can get the same batch as mine.
I'll probably just remove the glass lens and measure again.
My IMR is from bestinone.net too, they can do 2.9A in the Ultrafire XM-L P60 and UF-980L DD. Maybe you'd need to cycle them twice first. I always notice that the first charge does not give you the max juice.
If this is a ultrafire u80 body and according to the post, it should also fit a dbs v.3, would the the parts for the dbs and ultrafile be compatible also? Do you they both use the same pills?
U80 and DBS V3 caps I think one fits the other but not vice versa. Can't remember, one is too short.
Just in - Heatsinking performance. 283 lux at 1 second drop to 276 lux @ 8 seconds after turn on and stabilises. After 15 mins it is 272 lux. Anemometer wind speed 3-9kph (most of the time 6-9 kph), ambient air temp 29.6 deg C (HOT!)
Is this the longest throwing budget XM-L you know of?
You mentioned that its regulated. Does it increase in amperage draw as voltage decrease till the batteries are consumed while maintaining full output to the LED?
Manafont couldnt price match the Skyray clone with the Fandyfire. To bad, and Id buy the the STL-V2 if it was noticeably brighter. I think Im also done with olight products. Of all the lights Ive ever owned, the olights have had by far the highest failure rates.
