Test/Review of MBI Nuke 18650 1500mAh Test (Blue)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 18 hours ago
This is not a official battery yet, but one MBI is considering as a 18650 Nuke battery for his custom flashlights (I am wondering about what type of flashlight needs this battery).
DSC_4973
Official specifications:
  • MBI Nuke 18650 - Blue
  • Capacity: 1500mAh
  • Max Discharge: 10C
  • Max Peak Discharge: 18A (30sec)
  • Life/Cycles: 150
MBI%20Nuke%2018650%201500mAh%20Test%20(Blue)-info
The battery is a fairly low capacity battery, that can deliver a lot of current.
DSC_4972
DSC_4974 DSC_4981
DSC_4979
DSC_4980
MBI%20Nuke%2018650%201500mAh%20Test%20(Blue)-Capacity
I did get a bit enthusiastic with this battery and tested it up to 30A, i.e. twice the rated current.
As long as the current is at or below the rated current, the battery does very fine with constant capacity and perfect tracking between cells.
It did also handle 20A (Fits fine with the 18A peak rating), but 30A was too much.
MBI%20Nuke%2018650%201500mAh%20Test%20(Blue)-CapacityTimeHours
MBI%20Nuke%2018650%201500mAh%20Test%20(Blue)-Energy
MBI%20Nuke%2018650%201500mAh%20Test%20(Blue)-PowerLoadTime
Here the batteries does not track perfectly, I wonder if I did damage the cells with the 30A discharge?
MBI%20Nuke%2018650%201500mAh%20Test%20(Blue)-TripCurrent
MBI%20Nuke%2018650%201500mAh%20Test%20(Blue)-Charge
Conclusion
The cells has good high current performance, but the capacity on the low side.
Notes and links
The battery was supplied by MBI for review.
Helios-
Helios-'s picture
Last seen: 2 years 1 month ago
:~ Don’t we already have 18650 “nukes” that can do 20A with more capacity then this?
Do you have the LG ICR18650 E1 3200mAh 4.35v in line for testing?
Counterfeit 18650s, 2,<a href=“http://
HKJ
HKJ's picture
Helios- wrote:
:~ Don't we already have 18650 "nukes" that can do 20A with more capacity then this?
Yes, he is probably too late with this cell.
I have tested a protected Keeppower version of it: http://lygte-info.dk/review/batteries2012/Keeppower%2018650%203200mAh%20...
