FastTech SolarStorm SC01/02/03 lights
226 posts / 0 new
Boaz
Boaz's picture
Last seen: 11 hours 36 min ago
Not a good sign for weekend modders when TomE can't get it apart
Tom E
Tom E's picture
Last seen: 5 days 22 hours ago
Smile. There's a lot of things I can't get to open up lately. Actually I've been on a run of sorts of disappointments, at least I feel that way. Maybe it's the arthritis in the hands, strained ligaments in the elbow, back aches, dunno. I sure got a lot of excuses though Wink.
Sometimes you just feel like taking a hammer or a saw to it and see what results. Reminds me of that show where they cut things up to see what makes it tick... (ahh: "Sliced" was the show)
Serifus
Last seen: 9 months 3 weeks ago
well, mine arrived, and I really like the 01. the 02 was doa though, and it definitely has some sort of press fit pill and uses regular 16mm mpcb. im going to see if i can get it pressed out, and see why its doa. it also has a 3rd wire, but it is soldered to the body instead of the led like in the 01, so its definitely some sort of ground plane connection. also there is more then enough room in the sc02 for protected batteries
the Pill in the sc2 is definitely pressed in, I took a bit of wood about the diameter of an 18650 and tapped it out, will post pictures shortly
Turns out it was a bad solder on the led wires, I swapped it out with a glorious 5B tint and am really happy with it will post pictures soon
And its toast again. The switch is actually really fragile and not well attached to the board, there is some strain relief for it into the pill but it doesn’t seem to help very much. also it is very susceptible to shutting off when bumped on the bottom
freeme
freeme's picture
Last seen: 2 hours 37 min ago
Finally got my SC01 and 14500 from Fasttech! Delivered in 13 days!
Both at Highest mode.
UR14500P
AA Ni-MH
This flashlight will be perfect if:
  • it comes with memory mode
  • LOW mode is lower
1thedeals.comyoutubeAstroluxNealsgadgetsolight
M4D M4X
M4D M4X's picture
Last seen: 5 months 6 days ago
thanks for the comparisson!
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
Jerommel
Jerommel's picture
Last seen: 1 year 8 months ago
[edit]
….rambledabamble…
keltex78
keltex78's picture
Mine is definitely the XM-L2. Is the light you received SolarStorm branded or did they substitute the FandyFire?
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
Jerommel
Jerommel's picture
It’s SolarStorm branded
(BG sticker says SKU-129255 NW)
(So I’m crying in the wrong topic..)
So what do I do now?
(Cry in the BG topic, I guess..)
Tom E
Tom E's picture
Jerommel wrote:
It's SolarStorm branded (BG sticker says SKU-129255 NW) (So I'm crying in the wrong topic..) So what do I do now? (Cry in the BG topic, I guess..)
Guess you ordered the "Natural White" option? The specs clearly states "XM-L2 T6 3C NW" on the BG product page, so I assume you got options: through BG, and if they don't handle it, then PayPal. You paid for "X" and you got "Y" -- I'd dispute the item received as not what was stated.
For the PWM's -- they look fine to me, but I am clueless with PWM's unless I measured them on a scope. It was stated by others earlier the PWM's were not good, but again, I have no way of telling what's good PWM's and what's bad PWM's -- it all looks the same to me. Only time I even notice PWM's is when I'm working with a drill or a dremel with a light in my headband. The light I use in my headband is 9.4 kHz PWM, but the bit seems to stop spinning on occasion when on medium or low - weird effect but only time I've noticed PWM's.
Jerommel
Jerommel's picture
never mind
freeme
freeme's picture
I am not bothered by the PWM. It looks the same as my other flashlights…
Does it mean my eyes are getting bad?
Werner
Werner's picture
Last seen: 2 years 4 months ago
I got my sc01 yesterday, the best 14500 light I have so far. Very nice.
The Pwm is not noticeable for me but I confirm it has low frequency.
I used the highest low mode and it is a very nice light.
The size is super small for for a sideswitch light.
I will measure a bit and see if I can tweak the current a bit if I find time.
Tom E
Tom E's picture
The pills are press fit. I opened my SC03 by removing bezel/reflector, hammer tapping a 1/2" copper pipe from the battery tube end. Post #24 here: http://budgetlightforum.com/node/30782. The driver got pushed in slightly -- make sure you using something that makes contact with the edge of the pill.
Werner
Werner's picture
Thanks I hadn’t seen this thread…
Nemesis
Nemesis's picture
Last seen: 6 years 10 months ago
Wanted to try a 16340 light, couldn’t pass up the SC03 at this price.
Chicken Drumstick
Last seen: 10 months 2 weeks ago
I got the SC02 last week.
Very nice size and seems solid and well made.
Output is ok, thought it’d be brighter. I have a super budget XM-L U2 18650 light from DX that is brighter.
Beam is rather ringy too on the outer edge.
PWM on position 1 is truly horrific. – for those that claim not to be able to see it, simply wave your finger (or hand) in front of the torch and you’ll see the lovely strobe affect it produces.
The PWM is awful at all outputs on this variable mode. Not saying it’s worse than some other budget offerings, just a shame it’s so bad on a completely new unit.
Lastly while I like the light, the UI has to be one of the worst designed UI’s I’ve come across.
No instance access to High (and the instructions list the mode options reversed!!! ).
But to use the light you HAVE to use both modes regardless. So even if you have position 1 set to it’s lowest you can’t turn the light off without using Turbo. Friggin stupid design, that might as well just turn on in Turbo each time, then let you select a lower output should you want to.
bgyen
Last seen: 2 years 1 week ago
I got my SC02 today, but I think I got a dud. Put in a battery and push the button. It barely lights up. It’s like moonlight mode. Then I press it again and it ramps up brighter to max, but still it’s so dim you could stare right into it. It’s like it’s working, but only about 5% of what it’s capable of. And that’s if it even turns on. Most of the time after screwing on the cap (negative-side) it doesn’t power up. I clean off all the contact points, but no go.
Not sure what’s wrong with it. I just made a ticket with FT.
The light otherwise looks really nice. I like it’s size. I really wanted to try out the dimming feature of this light as I have a Niteye JA10 that has variable brightness, but I was looking for something that has higher output than the JA10.
Racer
Racer's picture
Last seen: 5 years 7 months ago
I made the missus cough up her SC02 long enough to try a protected Panasonic 3400 in it. It’s a tight fit but it does fit and the light works fine.
alphazeta
alphazeta's picture
Last seen: 2 years 10 months ago
I just received my NW SC02 from BG. It’s an XM-L and not an XM-L2. What a waste of time. This calls for a PP dispute I think.
Jerommel
Jerommel's picture
alphazeta
alphazeta's picture
Jerommel wrote:
@alphazeta: http://budgetlightforum.com/node/30911
Thx for that 411
I guess that’s the route I’ll go then.
FYI I wouldn’t have even bought this XML light for $10(probably not even for less)
Racer
Racer's picture
Gave the SC01 and SC02 away but I actually use the SC03. It’s probably my lightest 16340 light and has a very good output and tint on high. I plan to order an S10 eventually to round out my collection, but the SC03 is probably lighter so it’ll still get some EDC time. It’s not a bad little beater and it’s nice and lightweight in sweats or a hoodie pocket.
Jerommel
Jerommel's picture
alphazeta wrote:
Thx for that 411
Me neither. And I’m a bit insulted by the ‘solution’… I might take the PP route, maybe..
Racer
Racer's picture
Here’s another photo:
Boaz
Boaz's picture
Got a pair of nw sc01's  from banggod and they're an ok light for the money .hard to expect too much out of a 14$ light neutral tint  is not bad . The ramping on these lights is pretty worthless .Should have bought a sc03 instead of two AA/14500 lights .. They are small and fairly bright . Not bad /
roberta
Last seen: 4 years 5 days ago
Boaz wrote:
Got a pair of nw sc01’s  from banggod and they’re an ok light for the money .hard to expect too much out of a 14$ light neutral tint  is not bad . The ramping on these lights is pretty worthless .Should have bought a sc03 instead of two AA/14500 lights .. They are small and fairly bright . Not bad /
Good Day Boaz, Smile
Could You Please tell me whether the NW SC01 flashlights You received from Banggood are XML or XML-2?
Thank You Very Much,
Roberta 0:)
Greetings from The Land Downunder
keithd
keithd's picture
Last seen: 11 months 2 days ago
I bought an SC02 and an SC03 in CW a couple weeks ago. Couldn’t be happier with the SC03, and the SC02 isn’t a disappointment. I love the forward mounted switch.
In fact, I just placed an order for one more of each. They should make for decent hiking lights, especially the SC03.
WarHawk-AVG
WarHawk-AVG's picture
Mine from banggood were XM-L2 (some were getting XM-L)
neabue
I want to get the sc01 in the neutral white, but it sounds like they only have it in the XM-L. What would be the downside of getting this light in an XM-L instead of the advertised XM-L2? Is it really that big of a difference? (sorry, i’m new to the flashlight scene) Or would I be better off getting the sc01 in cool white in order to get an xm-l2? It sounds like neutral white may be more useful, but I understand that’s all personal preference. Thanks!
Jerommel
Jerommel's picture
Some shops offer XM-L2 NW also.
Not only Banggood, others too.
Prices vary.
I think you bought them before the hype, before the backordered batch.
