1. It's just one of many types of rechargeable batteries - LA(Lead Acid), Li-ion, NiMH etc. Each types normally has different charging requirement, cannot be mixed.
2. No, higher capacity will only give more runtime. Higher voltage battery (e.g 6V LA) will make it go poof.
3. Vf for cheap emitter normally just slightly lower than 4V.
4 & 5. Why are you partial to this company? Those cost only $10 around here, and that's retail. No way I'm paying $30 for it. All plastic, generic emitter, battery of unknown origin, WEIRD SPEC - first it's 5W, scroll down and it's 3W - also "GREEN" body and later mentions black.
The Crelant I mentioned will beat it to pulp in everything for same price.
If you really want a good $30 value for money, by my opinion, it's would be this $6.50 headband, an XML C8 on top (ebay/Ali $10), and a couple flooders on the side ($3 cheapie host + $4 XML emitter). That's my current setup, and I never want to go back to single headlamp.
1) I asked for their datasheet for the LED… I am attaching along… NOw I want to know the total lumens produced by 1 LED. then I will know the total Lumens produced by the 12 LEDs…
2) can someone see the datasheet for the LED and tell me how much LUmens is produced per LED… THey claim it over all 90-100 lumens is produced per Headlamp.
The datasheet unfortunately doesn’t say how many lumens are produced per LED. Instead it only refers to intensity in millicandela. Intensity is a measure of how bright the emitted light is at its hotspot. It tells you how well the LED throws. But unfortunately doesn’t tell you total lumens. A very throwy, focused light might have high intensity and low lumens. A very floody light might have high lumens and illuminate a wide area… but have low intensity and not throw very far.
Since the datasheet doesn’t say, that leaves us with experience. These are very generic cheap Chinese 5mm LEDs. Typical output is usually 5-10 lumens per LED at the emitter… less actually emitted out the front (OTF). So previous estimates others have given of 80 lumens sound in the ballpark.
However, if they are driven less hard than they could be or if they are at the lower end of the output spectrum (5 lumens), total output might be lower. The only way to tell is to take measurements or compare the light to others. This is where actually handling the light comes in. A previous poster mentioned he’d actually handled and repaired this same model of light and total output was around 20-30 lumens. Frankly, I’d take that hands-on observation as more accurate than an 80 lumen guess.
It is routine for cheap flashlight manufacturers to inflate their rated lumen outputs. It’s highly likely that the spec listed on the light is much higher than the actual output.
If you want a more accurate estimate of the total lumens from this light, you’ll need to send it to someone with the proper equipment for testing.
The outcome of the equations (and the calculators based on them) may differ from the data given by a LED or spotlight manufacturer, or from what you measure with a Lux meter, for several reasons. The manufacturer may specify the luminous intensity (in candela or milli-candela) perpendicular to the light source, instead of the average value over the apex angle. Another complexity is that the values for candela, lumen and lux are standardized for light with a wave length of 555 nm, or green light. For LEDs of a different colour, a weighting function should be applied, using a standardized model of the human eye. Standard Lux meters have, at best, only filters for daylight and incandescent light, and may therefore deviate significantly for LEDs (even white LEDs, as the spectrum is not the same as for incandescent lamps).“”“””
I completely agree with getting another headlamp instead of debating how many (few) lumens that one produces. Almost anything you buy that he mentioned above will be much better, and if you want a really good one, get the Armytek headlamp from Illumination supply, with the discount its only $80 I think and its up to 1010 lumens.
With the headband idea though…Im not sure what you use it for, but if you are moving around using it like for hiking, for me the headband is absolutely annoying and not very workable, the lights move around/get blocked, feel funny and change directions…not a good idea unless you are using it and not in motion!
That depends.
I recently received and modded this $12.— headlamp
I put a depolished, slightly wider lens in it along with an XP-G2.
Zoomed out it’s a flood without edges, so you don’t have a beam that moves with your head.
I think a wide flood TIR would be best though.
But fleabay also has cheaper headlights, also with built in charger and stuff.
Yes, Farhaj it’s probably around and about 0.7 Watt and probably some 40 Lumens
Devide it by 12 when you want to know how much per LED.
This has all been said and done by others in the previous posts in this topic.
It’s 12 ‘strawhat’ LEDs. Very cheap.
You would better buy this then:
It’s $4.80 and has built in charger also.
Looks like 1 Watt LED about 70 Lumen.
The company claims that the output is between 90-100 Lumens … how is this possible… so thats why I opened the light and got the datasheets for led and the battery from them… they also claim that it has 1 watts power output as written on the outside box… Now, they also claim they have a 3Watts Light as well… so I want to be more sure about its power and lumens before buying it… so, first can you clear out this for me about the first light…
I tried for fishing … but could not see clearly in water where even it was little deeper or waves forming… so I came to the conclusion it requires a higher Lumens Power…thats why I want to know and calculation lumens and Watts of the total flash light…
You’re simply not gonna get what you want from these lights. Now I don’t see a solution here if you still want to buy them. You get another DP 5W light (as opposed to 3W currently) and so what? Get another 60% lumens on top of 50lumens = 80lumens? That still won’t help.
Best case scenario, let’s say their claim of 100lumens is true. Then so what? That’s not enough according to you. Add 60% to that => 160lumens, still not gonna help.
You will want lumens in the count of 1000lm when spotting - definitely not gonna get it from these lights. Unless you’re willing to wear a couple dozens of them all at once.
You will also want warm colour for night fishing, it doesn’t bounce on wave so much and blinds you. These lights? They’re like 8000k, very very cold white. Now, you’d want 3500k or close to that region, you’re not gonna get them from generic LEDs.
Seriously though - you need CREE XML at least, in warm tint. My advice to you - try to get someone with a CC or debit card to help you order online. If you can do that, maybe we can help you with your ordering choices.
