Bro, well XM-Ls aren't mean to be throwers in small diameter aspheric form. My T9 copy made 18k lux @ 1m, which is the same as my UF-980L. If you get a 75 lens with shorter focal length, yep that can be throwers as then at the longer focal lengths they capture more of the 120 deg emitter light to collimate (check out the customs). 100k lux!
This is more meant to be a floodlight with throw as an option, it can easily flood 120 deg. XR-Es floor is narrower by design. And I bought it just for the design and close-in floodlight. With the pretty good heatsinking (it barely sags, same as M7X), ~ 120mm length, its really good for close distances flood with the ability to tube the spot a bit.
The UF recoil throwers (Q5/P4s) in flood, do a reflected bounce light lux meter reading, trust me the T9 floods much more.....though with the eyes without an A/B comparison, it'd be hard to see the difference due to how our pupils compensate. And with floods, it is harder to A/B than spots due to the hotspot sizes involved.
If you compare a XR-E in throw to a XM-L, then even reflectored lights a Solarforce MPP-1 does 50k would be brighter in lux than XM-Ls.
There used to be a Tank007 group buy, quite a few expressed that they do not know what is the purpose of a XM-L zoomie.
No offence bro, just wanna put it to be technically correct.
