Test/Review of Efest IMR18500 1000mAh (Purple) 2014
2 posts / 0 new
HKJ
HKJ's picture
Last seen: 5 hours 30 min ago
DSC_5260
Official specifications:
  • Capacity: 1000mAh
  • Min. Capacity: 1000mAh
  • Nominal voltage: 3,7V
  • Charge voltage: 4,2V ± 0,05
  • Discharge voltage: 3,0V
  • Max. discharge current: 15A (15C)
  • Max. charge current: 1A (1C)
  • Positive pole: Flat Top
  • Protection circuit (BMS): no (unprotected)
  • Chemical composition: LiMn (IMR)
  • Diameter: 18,30mm ± 0,1
  • Height: 49,80mm ± 0,1
  • Weight:40g ± 1
  • Charging methode: CC-CV
Efest%20IMR18500%201000mAh%20(Purple)%202014-info
A 18500 cell with a very high maximum current, the rating is higher than for many 18650 cells. This means the cell has a fairly low capacity.
DSC_5259
DSC_5261 DSC_5262
DSC_5263
DSC_5264
DSC_5265
Efest%20IMR18500%201000mAh%20(Purple)%202014-Capacity
The curves overlaps fairly well and the capacity is nearly constant. This is very good performance all the way up to 15A.
Efest%20IMR18500%201000mAh%20(Purple)%202014-CapacityTimeHours
Efest%20IMR18500%201000mAh%20(Purple)%202014-Energy
Efest%20IMR18500%201000mAh%20(Purple)%202014-PowerLoadTime
Efest%20IMR18500%201000mAh%20(Purple)%202014-TripCurrent
Efest%20IMR18500%201000mAh%20(Purple)%202014-Charge
Conclusion
These battery has very good high current performance, but the size limits the capacity (If you have 15mm more length, you can get more than twice the capacity).
With the performance of these cells, I will call it a good battery.
Notes and links
The batteries was supplied by Akkuteile.de for review.
HarleyQuin
HarleyQuin's picture
Last seen: 1 year 1 month ago
Thanks HKJ for another great review.
I like the 18500 format for lights that have some power while still being pocketable.
Some modded Solarforce L2m come to mind Love
This cell has more capacity than the AW IMR 18500 (red) and holds it very well at higher current. Seems to be truly manganese based, capacity suggests LiNiCoMn chemistry.
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
