its not too late - this will probably remain open until we get payment instructions
i added you relic & xelario - it looks like we are going to have a coupon code for this group buy - to use the code you will have to register on hkequipment.com
HKequipment also says they will take a payment directly to their paypal address
they have yet to confirm if they will take one or both methods of payment. (will update when they reply to my PM)
SG5 coupons are not working due to a $59.99 minimum required. Works if you add the reflector, but then you cannot add the reflector discount in. I suspect they forgot about the price discount already on the SG5’s.
Should we place a separate order for the reflector in order to use the discount code?
Edit: Answer posted before I even get the question out
I emailed HKE about the problem with the codes - its in the middle of the night over there now though, so it most likely will not be corrected for 6-10 hours.
in the meantime - even if your code is not working - you can place an order via paypal by sending funds to pay@hkequipment.net
just be sure to put your detailed order, and reference the group buy and your BLF name so they know who you are.
Are you sure the reflector is $6? I thought I saw it for $8, but can’t find the post. Mind you, it’s only an extra $1 from HKE if you buy the SG light.
