Picking up the new upgrade 2X sample from courier this afternoon so will have good look at quality and do field test, 6m lux test, plus runtime test. Then tomorrow night should be able to dedome it and redo testing.
Sincerely hope it is 120ish kcd stock because with just dedoming it will give 250k or so - and that’s 1000 meters ANSI - ideal for farm/outdoors/S&R/hunting spotlight.
This afternoon I received a sample of the new 2X and have now had opportunity to take a good look at it and do some testing. Light came in a very useful canvas carry bag with spare tailcap switch, rubber tailcap button, spare O-rings, good lanyard and guarantee card.
This is a beautifully made light - a step up from even last year’s fine 2X. Anodizing is better than last model, build quality is excellent, reflector perfect and new AR lens very clear. Threads are excellent and the light comes with double O-rings for IPX-8 waterproofing standard. Overall construction is 100%.
Lux tests will always vary depending on your light meter calibration and your batts, and I can only measure to 6m in completely dark conditions. My 6m measurement was 112kcd - which I think will improve to 120kcd or so at 10m - the best distance to truly measure throwers. Maxtoch did random testing and recorded 122 and 124kcd for two examples at 10m. This is a powerful thrower and I expect with just dedoming it will record 240-250kcd at 10m.
In an inital field test this beam is a real winner. The hotspot is actually quite wide and it is terrific for scanning wide areas quickly. The 120kcd throw also shows out at long range and the 2X picked out power poles at around 600 meters, and lots of objects past 400m.
This is another high quality light from Maxtoch. *They are really producing some very classy lights now and the 2X is a powerful, beautifully made light. I will start a runtime test shortly, but at this point I would advise anyone contemplating getting one to go do it. You won’t be disappointed.
I am looking forward to hearing of the new 2Xs running north of 350kcd. Will tune this one to that level also. As a stock light its a beauty - but at 350kcd it will be epic.
Torch became quite warm over runtime test - mainly because it was sitting on the carpet with no air movement to cool it. Heat dissipation is fine.
Runtime with my panasonic 3100s on continuous high beam is 81 minutes - quite good for a powerful light. Has Hi/med/lo plus an innovative twist head feature which gives a fast strobe. Medium mode is 46kcd - very respectable and likely to give hours of runtime.
Did a quick 2 minute de-dome on the 2X. Very nicely made piece of kit. Nicely machined, threaded and anodized. Quite heavy. I really should have put dark sunglasses on before I tested the beam on the white door at 4m though. :cowboy_hat_face:
Stock it read 112kcd at 6m, with an estimate of 120 at 10m. Maxtoch’s 10m tests showed 122 and 124kcd for two new 2Xs at 10m.
Tonight after dedoming my 2X’s peak reading is 237kcd at 6m, with an estimate of 245-250kcd at 10m - where throwers perform best. It is helluva powerful for a basic light with a 5 minute dedome!
On medium mode it read 95kcd at 6m - likely about 100kcd at 10m. Its medium is far more than most lights on high!
Conclusion - amazing performer - great thrower. ANSI distance measure on 245-250kcd = 1000 meters.
Note your results will vary a bit up or down depending on meter calibration and batts.
can’t wait to see the actual light,thanks before krono since i never owning a HD2010 before this M12 seems a winner for me if it available with NW tint
The M12 is spec'd at 94 kcd (converting from rated distance), which is awesome for a HD2010 size light in stock form. The AR lens, XM-L2 U2 on copper, and a fine reflector are probably why. I'm guessing it's between 2.5A and 3A stock.
I got one coming with one of the MaxToch 26700 cells, so I'll be posting details/review on it. I really like the HD2010 and Yezl Y3 style lights, so this is very similar, but higher quality, like the other MaxToch's.
I just built up two Y3's at 5.7A and 6.7A max, so I WILL be pushing this light in that neighborhood, eventually. I'll probably go with a FET based driver - will know more details when I get it, how mod friendly it is.
The 26700 really has my curiosity because they seem extremely rare. I see a 4500 mAh rated cell (no name basically) at MeritLine and Amazon, and the old Moli's at 2900 mAh. But a 5000 mAh - dunno, haven't found any yet googling.
