Whoa that is small - size of a sim card. I looked around - cheapest is $5 shipped for these (vs $1.40 for the bigger guy), quite a jump in price for tinyness.
Interesting why the red is always cheaper than green/blue version - easier to build due to Vf probably?
I like the readout style over the lights. It's larger, but if I can fit it in, I will use the readout style. I don't really need a low voltage warning, I just think a readout of voltage would be kind of different.
I don’t think they get cheaper than these. I’m probably going to grab some afterwards. I already have the bigger version in many colours, and I must say the blue LED is the most beautiful - kind of classy, expensive looking.
The numerical LED blocks are standard size. Three digits is too wide (>20mm). Maybe replace it with two digit block if one decimal place resolution is acceptable?
The ones from gigibaobao are better quality than FastTech, with trim pot and work to lower voltage, but still too big.
Another idea, maybe use two or three of the kind Helios posted set to different voltages?
I ordered a few of them from Fasttech and they won’t read voltage until it rises above about 3.3 volts. They do work great for RC lipo monitoring & portable solar cell and checking batteries in the field with out lugging a huge Fluke meter.
I think you could bitbang i2c with an ATtiny. You could take the voltage reading using the standard divider method on the ATtiny and then output it to the display. You’d need additional space for the larger firmware - probably an ATtiny85 with Arduino would be the most straightforward way to build it.
Ok, first two sentences were automatically translated into [I think you could BADA-BING SOMETHING with a THINGY. You could take the voltage reading using the standard DOO-DAD method on the THING-A-MA-JIGGER and then output it to the display]. I understood the last sentence just fine. More doo-dads and thingys suggests that it won’t fit in a small light.
Not at all! The Arduino environment works fine (ish) to write code for a bare ATtiny85, such as the ones we would use to replace an ATtiny13 in our flashlight drivers (they have a similar footprint). You simply write and compile your code to a hex file and then flash as we normally do. There wouldn’t be room for a lot of shenanigans (no stars), but I think there’s enough room for a momentary switch, voltage monitoring, and i2c. So the limiting factor is probably still the physical size of the display, although I did not look at what it needs for a power supply.
scottyhazzard I took a glance at the manual for that display. The tricky bit is that it wants two fairly different supply voltages. The good news is that it has an internal (boost) PSU for the higher voltage. The bad news is that the overlap between supply voltages is still very minimal, even taking advantage of that boost PSU. I think it’s possible that a simple 3.3v regulator such as the MIC5235 Microa mentions here could power the whole thing. It is a small component and requires one capacitor. The display itself requires 6 capacitors and 1 resistor when powered in this way. All in all I think it’s possible to add this stuff to a very small PCB or even onto an existing driver if there is a little bit of space. Any application that can accommodate a display of this size certainly has enough space. Even if running both VDDB and VDD off of 3.3v doesn’t cut it we could easily drive VDDB on one 3.5-4.0v MIC5235 and VDD on a nice comfortable 2.8v MIC4235. That’s still only 2 small components and 2 small capacitors. Bottom line is that there is no need for a bulky BEC (and the other bottom line is that needing 2 input voltages makes the BEC a less desirable route anyway).
EDIT: the display has a ribbon cable that requires soldering directly to a PCB. Rather than waste space why not just make that the PSU board and driver PCB as well?
Now for the host, what to put it in? Something that takes multiple cells I would think. M6, SRK or there’s that style that has 3 18650’s in parallel but one emitter…
