GB- MaxToch SN6X-2X - Now Closed
can’t wait to see the actual light,thanks before krono since i never owning a HD2010 before this M12 seems a winner for me if it available with NW tint :slight_smile:
The M12 is spec'd at 94 kcd (converting from rated distance), which is awesome for a HD2010 size light in stock form. The AR lens, XM-L2 U2 on copper, and a fine reflector are probably why. I'm guessing it's between 2.5A and 3A stock.
I got one coming with one of the MaxToch 26700 cells, so I'll be posting details/review on it. I really like the HD2010 and Yezl Y3 style lights, so this is very similar, but higher quality, like the other MaxToch's.
I just built up two Y3's at 5.7A and 6.7A max, so I WILL be pushing this light in that neighborhood, eventually. I'll probably go with a FET based driver - will know more details when I get it, how mod friendly it is.
The 26700 really has my curiosity because they seem extremely rare. I see a 4500 mAh rated cell (no name basically) at MeritLine and Amazon, and the old Moli's at 2900 mAh. But a 5000 mAh - dunno, haven't found any yet googling.
:party:
where i can find 26700 battery on sale?its bigger in diameter than 26650 isn’t?
Is this what they are built for, or what you are seeing?
Ooops, updated my post above. All these cells have their sizes in the model 26650 means 26mm width, 65.0 mm length. So a 26700 is 26mm width (same as a KK), but longer than a KK. I have one Moli 26700, and width wise it fits in all 26650 tubes, but it's too long to use in any 26650 light I have. It's longer than a TrustFire 5000 26650.
One Y3 is a full mod: domed XM-L2 U2 1A on Noctigon, UCLp lens, FET modified Nanjg, stripped stock driver as contact board, and my new custom e-switch firmware with moonlight, long hold to strobe from anywhere, etc... This light I tested at 5.70A on a LG HE2 or Samsung 20R.
L2 U2 1A on Noctigon, BLF17DD, stripped stock driver as contact board, and my new custom e-switch firmware. Tested this at 6.70A max (LG HE2). I got an extra amp out of this for 3 possible reasons:
  • BLF17DD board, not a Nanjg board (dunno if any difference in resistance, maybe?)
  • shorter wire between contact board and driver
  • possibly better solder point on the contact board - closer, less resistance to the spring
Both lights have spring bypass's, etc. - usual tweaks.
Sweet!
oh.. sorry. GB thread.. please continue..
Thank you.
Count me in
I hope this group buy works out. If not, you can count me in for the M12!!!
Thank you Ray.
To Krono, hope you can get the light soon. Look forward to your comments. :slight_smile:
I’m in for one piece.
Well noted :slight_smile:
Me too hoping that mudgripz or gadgetman can give us the 2-5 minutes dedoming tutorial for this one. A step by step pics or a video doing it would be better :wink:
Invoices to magnet, MoZuKa, troisanh, gorky, bkling, have been sent through Paypal.
Make sure to leave a correct address please. With telephone number will be better. Normally parcel with tel. No. will be despatched faster.
Thank you. :slight_smile:
Payment sent
Amanda payment send. Transaction ID: 23Y78154WF072033J
Not sure whether they do that for fees. If they do, not fair to ask them to show the trade secret publicly.
well received with many thanks. Check your PM please. Need double confirm about city name.
