GB- MaxToch SN6X-2X - Now Closed
I’m in for one piece.
Well noted :slight_smile:
Me too hoping that mudgripz or gadgetman can give us the 2-5 minutes dedoming tutorial for this one. A step by step pics or a video doing it would be better :wink:
Invoices to magnet, MoZuKa, troisanh, gorky, bkling, have been sent through Paypal.
Make sure to leave a correct address please. With telephone number will be better. Normally parcel with tel. No. will be despatched faster.
Thank you. :slight_smile:
Payment sent
Amanda payment send. Transaction ID: 23Y78154WF072033J
Not sure whether they do that for fees. If they do, not fair to ask them to show the trade secret publicly.
well received with many thanks. Check your PM please. Need double confirm about city name.
Done.
Gadgetman does the dedoming in a few minutes and would not think of charging for that small service. I’ve asked him to post some tips on the process.
How does it focus after dedoming?
can you please invoice me - my paypal is jmpaul320(at)gmail.com
Thank you mudgripz. :slight_smile:
paypal sent, thanks Krono and Amanda.
Linh
I must have missed you jmpaul…sorry!!!
lol its ok
I messaged amanda but no response yet
i think its still early morning in the far east
My sample light came in! Pics and some comments here.
Looks great - I seriously like my dedomed new 2X.
Here’s gadgetman’s 5 minute dedoming method:
“Basically I hold the LED board in a vice with little wooden soft jaws I made up to provide insulation. I use a hot air attachment on a gas powered soldering iron (not a gas torch) and heat the underside of the board until I see the lead flow (melt). Then I gently press down on the dome with a concave ground screwdriver and hold it for a few seconds, making sure not to move the LED. This lifts bottom of the dome around the four sides of the emitter surface as well as testing if the dome is soft enough; if not soft enough I apply a little more heat.
Once soft enough (and the solder has taken again) I lift the dome off by popping a screwdriver under the edge of the dome on the opposite side to the fine gold wires. Normally the dome will just pop off with a little pressure. If the dome does not soften enough or it is reluctant to pop off I soak in petrol. The heating and lifting of the edges speeds this process any way.
Similar to this but it pops off a lot quicker and cleaner.
[video]https://www.youtube.com/watch?v=vfC3n2jlZY4[/video]
Just sent :slight_smile:
Alright. Can’t stand it anymore. Put me down for one.
acumenflashlights(at)gmail.com
