Test/Review of Eneloop AA BK-3MCC 1900mAh (White)
Official specifications:
  • Cell size: AA / LR6 / R6 / MN1500
  • Dimensions (radius x length): 14.35 x 50.4mm
  • Mass: 27g
  • Typical capacity: 2000 mAh
  • Min capacity: 1900 mAh
  • Life cycles: 2100
  • Brand name: Panasonic Eneloop Pro
  • Cell type: LSD NiMH (low self-discharge nickel metal hydride)
  • Memory effect: No (can be topped-up with no long-term capacity reduction)
  • Cell voltage: 1.2V
  • Colour: White
  • Charge retention after: 1 year 90%, 3 year 80%, 5 year 70%
Maximum temperature raise at different discharge currents: 1A:+1,2°C, 2A:+3,0°C, 3A:+5,3°C, 5A:+10,0°C, 7A:+14,4°C, 10A:+19,5°C,
This is the newest generation eneloop where the Panasonic name is highlighted.
The performance is about the same as the older generations of eneloop.
Conclusion
As always Eneloop has very good performance and they are promised to last a long time.
Notes and links
The batteries was supplied by a reader for a review
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
Your tests are greatly appreciated.
I have a question about capacity. Is there a general rule that tells me how deeply an eneloop is discharged based on voltage. For example 1.35V is 50%???
Thanks
Thanks for all your reviews. You are a reference to me. :slight_smile:
I suspect that you are doing this in your job too? What do you do exactly? (just curious)
No, some years ago I did develop electronic, but now I mostly do software. I do maintain a full electronic lab at home with a lot of equipment.
Oh ok.
I’m a you graduate. I have a Master in µelectronics and I’m currently trying to get some equipment at home, but my budget is tight.
I really like your reviews. You should think about posting some pictures of your home lab equipments!
Yes, equipment can be expensive. Some people buy second hand equipment, old HP and Keithley stuff is often perfectly fine.
Check some of the links at the bottom of the review, there are pictures.
