I don’t see any code problems in that case, assuming you’ve got F_CPU defined and it didn’t come through in your paste. To make matters a little easier on me I renamed your variables back to the stock names, there are very few changes and they all make sense: Saved diff hv94kqvv - Diff Checker
My TIR came today, the lens seems to be glued into the holder :( I'll get the dremil out later and see what can be done, hopefully I can get it cause I was really excited about the new flood beam pattern.
The TIR came out, not just popped out like I thought but I got it (actually had to melt the holder with a soldering iron). The neutral white 40* beam is very even, no hot spot at all which is about perfect for me in the role this light will fill. I also really like the look of the TIR better than a smooth one, still I’d prefer a reflector but this is more than adequate. Also swapped the XP-E2 for a XP-G2 on a 10mm sinkpad so I could increase the turbo timer up to 60sec, step down was changed to 204 (~80%).
old vs. new
Beam shots coming tonight. The only thing else I’m considering changing is adding one additional mode but i’m not sure, I usually dont like more than 4 modes so I’ll probably just leave it as is, all in all I’m very happy with this whole build, much much better than stock.
Back on the earlier topic of memory: I have now used both on-time and off-time with “no memory” setup. Off-time with no memory is what you want, it behaves exactly as you would expect a light with no memory to act: half presses while the light is on do advance modes, but leaving the light off for a few moments causes it to start in the first mode when turned back on.
Sorry for the delay in checking this out, it ended up not happening until I had a need for it. Go figure right? 0:)
Wait so you can just flash off-time without adding the extra cap?
Damn I hate my broken programmer, I want to play…ordered a set of 40 breadboard jumpers at the same time as my new programmer from the same seller, jumpers came today, programmer won’t be here till Wednesday, WTF…
You guys are getting confused. You can convert any nanjg based, non-eswitch driver to offtime instead of ontime by adding a capacitor to physical Pin2 and flashing the STAR offtime firmware. For no memory you comment out “#define MEMORY”. THE CAPACITOR IS REQUIRED for this firmware to operate.
Adding the capacitor is simple and easy and you’ve got tons of space for it in this build. Flash the firmware with desired settings and then add the capacitor, it will block your clip. It goes straight from pin2 (star4) to ground.
Good news, after messing with it for DAYS, I’ve got my old programmer up and running again (no clue what was going wrong but last night I decided to give the old girl one more try and it worked!).
I’ve gotta build and program two more drivers for a guy here in a bit but then I’ll be getting back to this. First goal is to lower moonlight more but then I’ll start working on off-time.
Sounds good! While it’s on my mind, you’ve got some wiggle room on the cap spec if you need it. Look in the STAR firmware discussion thread for HarleyQuin’s post on the subject, but it sounded like anything from 0.5uF to 1.0uF would be fine. A bit more probably won’t hurt anything either.
I just deleted it all together, so the E12 is up and running with on-time and memory turned off, it works exactly how I want a light to work, the only thing is even on 1 I still cant get moonlight all that low. My test bench XM-L2 is alot lower with this exact driver just wired to it, thats the one thing thats still a little dissapointing.
If you like what you have now it’s almost certainly due to not having tried the same thing with offtime.
scenario:
LL-L-M-H (standard on this firmware w/ moonlight)
If I’m in medium and use the light a while and give it a tap, should I end up in LL or H? (ontime makes LL)
What about if I’m in LL for a while? Should a tap just leave me in LL? (ontime makes LL)
I start with the light in LL and tap through to M and immediately turn the light off, which mode should it start in later when I turn the light back on? (ontime makes H )
I can’t imagine a scenario with a reverse clicky where you would want a short tap during usage to reset to the first mode. offtime corrects all of this behavior: in the first example the tap would bring to to H, in the second example the tap would bring you to L. In the third example it will start in LL, as expected when first turning the light on in any scenario using offtime w/out memory.
Heheh, that makes a lot more sense to me. After trying on-time w/ memory disabled I was flabbergasted that you could find that appealing. Very difficult to use w/ no upside I could find!
I’ve got the preflash issue figured out however there’s no way I can fix it on this light with a tiny10. I was getting the same preflash on my TC300 (w/MT-G2 and BLF20DD) so I put a 10kohm resistor on R4 and it totally solved it!
I’m going to try to file the “wings” fenix uses into a 17DD and make it fit direct so I can have a pull down resistor (unless switching to a BLF10DD V1.2 fixes it once they come in)
Is R4 the gate pull-down resistor? Looks like it to me at a glance. If so, it seems to me that you have space to do that on the tiny10. On the FET side of the board you just put the resistor between the GND ring and pin 1. Maybe right around where the board is marked U2.
