AA-zoomie at dx
The intestines might be the same as that AAA zoomie I did that short review on.
It’s the same LED and only takes AA, not 14500.
It’s overpriced… :frowning:
WB had it on promotion or group buy about 6 months ago. Anyway they have it cheaper with wallbuysfantasy coupon than DX.
Ah, the pictures on Wallbuys make it look cheaper ;-) . Anyone bought it? the coupon works, just checked.
Wonder how it compares to the “classic” zoomie:
Torchlight C78
My guess is that the performance will be just the same. It is more that I like the looks of this one than anything.
Looked over the spec. This may perform better than C78: XP-E R5 vs Q3. And looks “modern”.
IIRC R2 is the max bin for XP-E. Anyway, Chinese bins claims are about the same as Chinese lumens, you can’t trust any of them :wink:
Could be an error. This page now says XP-G R5 (but the link still says XP-E R5):
http://www.dx.com/p/trustfire-r5-a3-cree-XP-E-R5-3-mode-230-lumen-memory-led-flashlight-1-aa-1-14500-39062
Emitter BIN: XP-G R5
The r5-a3 has always had a xpg. The light from the OP shows a xpe in the picture, and -coming from dx- it could be any bin, but more probably a q5 than a r3 (which is the top bin for xpe).
Nice looking zoomie. Good knurling, has heatsinking, and overall looks cleaner than a Sipik 68. Also appears to use a larger 20mm lens.
I expect in performance it’s probably the same as a Sipik 68.
…it’s probably that lens that everybody uses…
I think the sk68 lens outperforms those.
It depends on how you define performance: the (indeed in many flashlights widely used) lens has a larger diameter and longer focal length than the sk68 lens, it will have a bit more light loss than the sk68 when zoomed in, but also the (smaller) hotspot is a bit brighter than the sk68. Throw is highly appreciated here at BLF.
So I notice… :slight_smile:
I’m more a OTF lumen guy I guess…
I’ve always loved the form of the c78.
SK528 looks good. Will get a few if there is a group by for it. :bigsmile:
What is the point of making holes in the bezel? :Sp
probably so if you place the light face down when it's on you can tell you left it on. A little bit of light will escape the holes . I'm not saying it's a brilliant design concept but thats my guess .
So did this one work out to be worth having?
SK68s and #3 zoomies are down to $2 apiece nowadays, if you’re a bit patient and search eBay and AliExpress.
But they’re finding new and innovative ways to make them cheaper; lately I find the pills are made of old dried chewing gum, I mean, some cheap gray alloy …
Hello djozz? What’s the verdict on this little zoomie after putting some time on it?
And my standard question: Does it look easy to put in an amber emitter?
Wow, I can not remember having this one, and it is not here anymore. I gave away a sizable box of flashlights a few years ago, it may have went into that.
The only thing I have for you is that if it was any better than a sk68 I’m sure I would remember it.
