How are the sliders on the VP2. I stopped using my VP1 for 18650 because trying to pry back the slider and holding it in place while the cell is inserted became too much of a pain. I now mostly just use side by side SP2s.
âThe slots have raised battery connections, i.e. flat top batteries can be used. The slider works very smooth and can take batteries from 30mm to 71.2mmâ
We canât compare the 2 chargers since the Opus is an analyzing charger/discharger, including facility for Nimh, while the other one (VP2) is a pure Li-ion charger only, (full list of functions not yet known) for the âVP4â.
HKJ, I donât think Iâve ever said this before, but Iâve come to greatly appreciate what you do over my past year on BLF: reviews, discussions, and otherwise. Thank you for yet another excellent post!
Yes, but it is also fairly expensive and and requires a little knowledge from the user (You must select the correct voltage and current).
The VC2 is also a fairly interesting charge because it has capacity display, but except for that it is fairly limited in functions (Review in about 2 weeks).
