10 watts in a XP die size? Better use Copper stars and then some. So, XM-L will be 20 watts? But maybe by them they will figure out how to hold the CRI. I wish Nichia would step up and make a larger die 90 CRI led.
Gree will have to call it something else. What's the next letter in line? XR-S or XR-T? Time for the Chinese flashlight manufacturers to step up and make some better heat sinking in ALL their lights.
Based on my calculations I see XM-L2 as having a 3mm by 3mm die, XP-L a 2.7mm by 2.7mm die and XP-G2 at 2mm by 2mm. I resized photos of each LED to they real size and measured the die by referencing the overall size of the LED.
I am talking about the die, not the footprint which the XP-L share the same with the rest of the XP family.
EDIT: I do not think one can rely 100% on the photos as the dome distorts the size of the die in comparison with the overall dimension of the footprint.
Oh Ya, that's wut I'm talk'n bout - I don't care bout the dye, but the mounting is the important part. Triple Noctigons!! Well.. maybe the dye does make a difference with focusing, beam patterns, de-dome effects, etc...
I guess you mean the surface area covered in phosphor that emits light? The relevant bit to throw improvements? I had assumed we were talking about which mcpcbs would suit, my bad.
it’s all speculation to this point. possibly removed from the datasheet on purpose to hide variance/future changes
given the cree ‘HD’ trend of xp-e -> xq-e, xp-g -> xb-h though it would make sense the xp-l is the same die size as xm-l (2x2mm)
should provide an interesting test of thermal coupling between the xm and xp packages at the very least!
Having a xp-size thermal pad, the XP-L can expect to handle heat somewhat worse than the XM-L2, at high current. But only testing that will give the real answer.
It’s the XML version of the XBH. Basically just an XML2 in a trimmed package…. no no improvement for throwers.
For flashlights, main use I can see is this might be usable on 20mm triple XPG stars. I’m not sure it will fit in the Carclo optics though, as the dome is larger than an XPG dome.
Oh I need those to upgrade a few SK68’s (I don’t have any non-zoomable throwers with XP-G stars yet)…imagine being able to use the same die size board, and having the teeny weeny emitter be able to push as much light as an XM-L w/o changing the zoomed out die pattern, nice!
