But why did they make the i3 longer than the a3 (70.8mm vs 66.5mm), brighter min with less run time (2.5lm/20h vs 1.8lm/50h, official numbers anyway) and less bright med and max with less run time (20lm/1.5h vs 22lm/4h; 70lm/0.7h vs 96lm/0.9h)?
They probably didn't decrease the output any, they just redid their official measurements to be more accurate since the "name-brands" are being a lot more particular about having their quoted measurements come closer to ANSI standard because of consumer complaints. The 96 lumen was always way off. It was always more like 60 OTF lumens when tested in an IS. The longer length is probably a result of the redesigned tail. The keyring attachment was always a nub at the end. Looks like the lengthened the tail so they could fit both a keychain slot and the new screws for the pocket clip while now giving it the ability to tailstand. 4mm is not that much added length for the more functional design.
I ordered one from Lightake for my wife in June, ordered a Q5 and received an R5.. all for about 19 dollars including shipping.. (used a coupon that I found on the net)
But now my funds are a little limited, and have a few things in mind that I want to buy.... hmmm.
if they go on clearance... (if anybody finds this out) let me know
I doubt they changed anything on the driver at all. They just decided to make their specs more accurate. Won't know for certain until you get one to compare side by side. 2.5 lumens is still pretty darn low.
the a1 doesn't officially take rcr's now? really? dumb move if this is true..also they're not keeping the sa line? my sa1 is one of the best lights I own..that sucks..
I'm guessing that the lack of official RCR support may have something to do with the move to the XM-L emitter. The "reputable" manufacturers seem reluctant to officially list rcr support on their tiny lights with XM-L. Probably concerned about too much heat and they don't want to warrant it. 4sevens did the same thing with the mini123x.
Its unclear whether Olight will release anything equivalent to the SA series. I would guess no because they were undercutting their own product line.
never heard that before. I know Olight makes makes the 4sevens light. That doesn't sound right since Olight has been making lights for quite a while and 4sevens started as a dealer of Fenix and Nitecore. Can you provide some links to back that assertion up?
Got it. Thanks. That explains even more why ITP is gone. Also explains even more why Olight won't give the i1 official support for RCR. From the MiniX, we can pretty much guarantee that an RCR will work though.
Not CEO, right? David, who runs (not sure about ownership anymore) 4Sevens, is Chairman of the Board at Olight. Other than saying they have a "strategic alliance" or something like that which will create synergy, they've never said what it actually entails. I imagine either Olight bought part of 4Sevens or vice versa. At a minumum I think Olight will be building more of 4Sevens' products than in the past and can buy bigger orders from Cree (Olight, iTP and 4Sevens were the only ones with S2 and S3 XP-G LED's). The thing that makes me think there is still some pretty significant separation is that David lives in the US (in the Atlanta area like me), even though he is of Chinese descent.
Not sure I'm crazy about the longer i3, though I don't doubt the clip is sturdier now. I took the clip off of my A3 and it lives on my keychain.
