I presume its a buck or buck boost driver. Pictures?
AVR microcontroller with programing header pins.
I would lose those fins at the tail. Serves no purpose & will just collect dirt.
Less stainless steel at the tail. Its not visually balanced with the head.
This is why I have to replace the driver in most of my lights. I cant stand it when I want to quickly change from high to low, or low to high, and I get in the obnoxious blinkie modes.
If you absolutely must have obnoxious blinkie modes, put them behind a 3 second long press so I don’t have to cycle through them by mistake.
Under $20 as for now, but final production cost once everything is said and done will hopefully be under $30. I did say it was going to be affordable right :) But the quality is VERY HIGH, considering the price.
Im not big on knurling, I find things drop if I let them go, not because of the lack of knurling. Ive never been holding something like a torch in my hand and had it drop despite my grip due to the slippery surface.
No PWM. Check! Shouldn't be hard, as all it is is programming. Maybe 100%-30%-5%-moonlight?
Once the driver is completed by Mr. Fang, I will upload pics and give more info about it.
As for the fins, whats wrong with them? I like them :) That and they are based off a pre-existing mould that Warsun already has, which makes the price very cheap for us. To lose the fins, they would have to create a new mould, which cost $2000-$5000, so I think we will just keep them :)
I didn't think of this, but makes a lot of sense. Also, I forgot to mention one can turn off the light from the side switch by holding it for 3 seconds, basically putting it in standby. I think that would be a better for a long press. That being said, maybe we can make it a quick 3x press within 0.25-0.35 seconds to activate the hidden strobe and beacon modes? Surely no one is going to to be changing modes that quick, will they?
I agree. It is an easy fix, but was told by Mr. Fang it would bring up cost. As it is now, we would be getting the 1x18650 base tube, then could presumably can order the extra tubes to extend the flashlight as an additional option. But I will keep this in mind. Trying to keep cost as low as possible.
I love ramping modes as well! I will inquire about this, and see if it can be done as well as how much more, in both effort and cost it will add. I'm really trying to find a perfect balance of modes, that won't make it complicated to operate. Seems I will have to put alot more thought into how this will be implemented, and also make it usable.
As for the AR lens, I will ask and see how much more for it.
After checking out the Warsun website, this appears to be the MX900 with a stainless tail cap and then upgraded driver and having lost the dayglo green stripes on the extenders.
Myself, I would prefer the ET26 with maybe one extender, or none and a really hot 4 amp custom driver. It will run a 26650 or 18650 and then you wouldn’t have the hassle of Buck driver and serial batteries, just an easier mod freindly unit when one battery.
ET-26 is only 5mm thicker at battery tube so it is not a club. Head diameter is listed as 49mm, so just 1 mm bigger then the MX900.
What is the difference in Reflector depth between these 2 models?
It’s all good, I do not currently have any Warsuns and have been waiting for them to get some distribution, but I am all in.
Great to see a Mfg. willing to do a custom run that would appeal to it’s customers.
I like this. I find that this makes a versatile driver. Honestly the Q-lite Rev A from intl outdoor is a good basic driver that I like a lot. I like it better than the standard Nanjg 105c because I can’t accidentally change groups to the blink modes~~ which I do quite regularly.
You are correct, the BLFX is based on the MX-900 which was chosen for it's square knurling and good looks! Mr Fang will not make the driver go over 3 Amps due to Cree's data sheet stating 3.0 amps max. He is very firm with this and I see why he will not go above 3A. It brings potential and unwanted overheating/short lived driver and LED issues. So we decided to make the driver 3A max.
We are also in talks about the ET26 as well, being as it can do 26650 or 18650, but that would be for a later date. As of now, we are focused on getting the BLFX - 18650 flashlight designed and produced, and see how well it is received being 18650's are the most popular li-ion battery format for flashlights on this forum. The 26650 battery is not so widely used, or available, or affordable as the 18650 batteries are, that's why we chose the 18650 flashlight for now.
I think the bezel depth block the light thus reducing the output somewhat… I agreed the tail cap just too much for me not to mention different color than the body is kind of turn me off from buying the light…
If anything I would like the ET26 or A60 with extender tube goes to production with 3A driver as it gives option to use different batteries and option to use the light as dual function to charge other device ( smart phones, Ipad…etc )
BTW with all my Warsun light… why do they made the switch on the side the same function as the one at the bottom?
can they just make the bottom as power on or off and side switch as modes? just like convoy L4 or Yezel Y3 lights?
Tail-cap lock out?
Will this accept longer batteries or flat tops?
Ramping would be a plus.
How about parasitic battery drain?
Have you considered a turbo mode with a timed step down?
