code is ready for testing. it does work with a small testing ledā¦ so onward!
That is awesome. I wish more big ass lights came with this. No BS light bars or color changing leds. Just a display. Simple. Good job :-)
Iām confused, I dont have a display in this build, not yet anywayā¦ just a simple regular led that glows at the same time as the main led.
was pondering putting a small lcd or oled or 7-14 segment led display.
Aināt nothing wrong with a PVC build. I know there are a few fans of it here. Me being one. Check out my holy hot spot Batman thread for proof.
Looks like this will be the most advance build FW wise, which is where the real future of lighting resides. Keep up the good work.
thanks, just checked my pwm freq with a āscope. and its around 4khzā¦ is that good? I can prolly go up to maybe 10khz, possilbly
Me too! Looking like this will be interesting.
thanks for watching
Sorry, Iām not a good judge of PWM. Traditional SRKās donāt even bother me. I only avoid it when working under the hood or with other dangerous moving machinery. 4K sounds good to me though.
well I don tthink someone (me) will use this under the hood or under a car well I could but its kinda overkill for that use
anyway. maybe tonight or tomorrow Iāll get everything wired together and post some short videos of it actually doing something before I get some pvc parts to try and package it up
two videos of the guts workingā¦ now to build a case
I'm up to wiring as well. When do you think you can come around?
Iām up to wiring as well. When do you think you can come around?
what help you wire yours up? nawā¦ I gotta build my case yetā¦
I spend most of my time on the host and as little as possible on the driver which is silly given the driver is the heart. Nice to see it being done the other way around.
I think I spent maybe 10 mins total on the code. more time was spent attaching wires to things and connecting the wires together my code is simpleā¦ about 10 lines longā¦
unless I decide to put modes and or a indicator/display of some sort on it.
A lot more in there than just code but even your minutes spent are more than I do.
thanks I think :>
anywayā¦ tomorrow I hope to get some of the parts to start making the caseā¦ and a power switch
Bump for update in first post, new photos will be posted shortly
Those couple of leds are really pumping out the light. Have you had extended runs yet? I was just wondering how well the heat sinks work.
not together noā¦ but the cool white heatsink does get warmā¦ not hot but warm, the driverā¦ very warm almost hotā¦ so there will be ventilation, will mount a fan to each ācannonā Iām pondering calling it a light faucetā¦ and maybe getting a waterfaucet handle for the pot
when pwmād the drivers and heatsinks dont get warm reallyā¦ under say 80% fullā¦
Iāve got a handle mounted, mounting main power switch shortlyā¦ then I have to drill vent holes for the led heatsinksā¦ then figure out how Iām gonna mount the fans and cut vents for those
then I can cut holes for the wires that have to go between each podā¦ then attach the pods together and start wiring things together, taking lots of photos as I goā¦
bump for photos of case postedā¦
