Sorry, Iām not a good judge of PWM. Traditional SRKās donāt even bother me. I only avoid it when working under the hood or with other dangerous moving machinery. 4K sounds good to me though.
well I don tthink someone (me) will use this under the hood or under a car well I could but its kinda overkill for that use
anyway. maybe tonight or tomorrow Iāll get everything wired together and post some short videos of it actually doing something before I get some pvc parts to try and package it up
I spend most of my time on the host and as little as possible on the driver which is silly given the driver is the heart. Nice to see it being done the other way around.
I think I spent maybe 10 mins total on the code. more time was spent attaching wires to things and connecting the wires together my code is simpleā¦ about 10 lines longā¦
unless I decide to put modes and or a indicator/display of some sort on it.
not together noā¦ but the cool white heatsink does get warmā¦ not hot but warm, the driverā¦ very warm almost hotā¦ so there will be ventilation, will mount a fan to each ācannonā Iām pondering calling it a light faucetā¦ and maybe getting a waterfaucet handle for the pot
when pwmād the drivers and heatsinks dont get warm reallyā¦ under say 80% fullā¦
Iāve got a handle mounted, mounting main power switch shortlyā¦ then I have to drill vent holes for the led heatsinksā¦ then figure out how Iām gonna mount the fans and cut vents for those
then I can cut holes for the wires that have to go between each podā¦ then attach the pods together and start wiring things together, taking lots of photos as I goā¦
More photos added to case postā¦ worked on it a bit more before work this afternoon nearly ready for connecting stuff inside and seeing how it looks onā¦
yay I should be finished in a few more daysā¦ unless I find Iām missing something else! YAY.
