thanks for watching
Sorry, I’m not a good judge of PWM. Traditional SRK’s don’t even bother me. I only avoid it when working under the hood or with other dangerous moving machinery. 4K sounds good to me though.
well I don tthink someone (me) will use this under the hood or under a car well I could but its kinda overkill for that use
anyway. maybe tonight or tomorrow I’ll get everything wired together and post some short videos of it actually doing something before I get some pvc parts to try and package it up
two videos of the guts working… now to build a case
I'm up to wiring as well. When do you think you can come around?
I’m up to wiring as well. When do you think you can come around?
what help you wire yours up? naw… I gotta build my case yet…
I spend most of my time on the host and as little as possible on the driver which is silly given the driver is the heart. Nice to see it being done the other way around.
I think I spent maybe 10 mins total on the code. more time was spent attaching wires to things and connecting the wires together my code is simple… about 10 lines long…
unless I decide to put modes and or a indicator/display of some sort on it.
A lot more in there than just code but even your minutes spent are more than I do.
thanks I think :>
anyway… tomorrow I hope to get some of the parts to start making the case… and a power switch
Bump for update in first post, new photos will be posted shortly
Those couple of leds are really pumping out the light. Have you had extended runs yet? I was just wondering how well the heat sinks work.
not together no… but the cool white heatsink does get warm… not hot but warm, the driver… very warm almost hot… so there will be ventilation, will mount a fan to each “cannon” I’m pondering calling it a light faucet… and maybe getting a waterfaucet handle for the pot
when pwm’d the drivers and heatsinks dont get warm really… under say 80% full…
I’ve got a handle mounted, mounting main power switch shortly… then I have to drill vent holes for the led heatsinks… then figure out how I’m gonna mount the fans and cut vents for those
then I can cut holes for the wires that have to go between each pod… then attach the pods together and start wiring things together, taking lots of photos as I go…
bump for photos of case posted…
Holy smokes! 8) It’s handheld, I can see the handle
yup barely
More photos added to case post… worked on it a bit more before work this afternoon nearly ready for connecting stuff inside and seeing how it looks on…
yay I should be finished in a few more days… unless I find I’m missing something else! YAY.
I think you win the most complex build award! Wow, I am impressed with your skill level. Beam shots out yet?
Nice build, can’t wait for the finished product.
complex? not really some of the others seem more complex to me.
closest I have to a beam shot are the videos in the third post I think…
once I get everything connected I’ll see if I can take a beam shot…
