Test/Review of GTL LS16340 2300mAh (Gray)
Very cheap, very high capacity, can they be anything but a winner? (See conclusion)
Official specifications:
  • 100% brand new 4x 16340 3.7v 2300mAh rechargeable batteries
  • Perfect for Flashlight, Photo camera ........
  • Model : 16340 ( Replace for CR123A, CR17345, K123A, VL123A, DL123A,5018LC, SF123A and EL123AP ) This is wrong
  • Capacity: 2300mAh
  • Voltage: 3.7v
  • Chemistry: Li-ion
  • Recharge: up to 1000 cycles
The rated capacity is about 7 times to high.
The battery can handle up to about 1A load, above that the capacity goes down very fast. The curver tracks fairly well.
Conclusion
The battery does not deliver what it promises, very far from, it is a low capacity 16340 battery without high current capabilities (This was as I expected, cheap high capacity LiIon does not exist).
The battery is useable, for some stuff, but it is very easy to find better batteries.
Generally speaking I will call this battery a looser
Notes and links
Comparison to other LiIon batteries
Is this the worst battery ever? :smiley:
:D
Thanks for the review.
2300mAh lol
slingshots :slight_smile:
Lets go kill some zombies :stuck_out_tongue:
that looks like idi amin dada
is the capacity really 2300mAh? :~
Definitely ….
If you connect about 10 of them in parallel.
the new standard for inflated chinese claims.
thanks for the review.
GTL batteries… not meeting specs… say it ain’t so…
