I’d suggest that what ever you buy has a jack shaft so that it has a low min. speed. Should be about 210 rpm or so. Very useful for bigger bits or hard material. In my experience such drills are often better in quality than their higher speed brethren.
If you can examine one for runout before buying that would also be a good idea.
I rarely use low speed, only for drilling troublesome stuff like copper, sometimes aluminum. For any kind of end mill or carbide it has to be set to max speed or else it grabs and chatters and generally makes a total mess of things.
I do some work in metal and also in wood. Bigger holesaws and the like work better at low speed. I imagine that low speeds wouldn’t be as important for most flashlight mods. Shouldn’t cost much more however so may as well cover all eventualities?
Comfy, you think it won’t be able to take the ghetto mill action that I plan for it? I looked at some others but the price quickly triples. I was also looking at Craiglist for old ones that have endured the test of time and coming up with a lot of the harbor freight, sears drill presses. I like that price with the coupon, that was a nice surprise. I guess my question is do you think that it could consistently be accurate to a 64th of an inch? I suppose I could measure a smidge bigger, then sand and buff to tolerances…
It seems like it lost a lot of it’s torque over the winter, drilling into some steel last week and the thing kept stalling out. Thought maybe it was just a dull bit, but that was not the case.
Belt is good, no slippage so it just seems like the motor is laying down.
I really have not had a ton of hours on it since I got it.
But, hey with HF you have 90 days to see if it works for you, just keep the receipt and they will take it back if you are not happy with it.
As for mine, I am going to search for an older USA made beast at some upcoming community yard sales.
A guy up the hill from me used to have a garage full of the big stand up drill presses like we had in my high school.
Wish I would have gotten one from him. He moved now and I have no way to contact him.
But they are out there and I will find one.
Good luck with your search and let us know what you got and how well it works,
Keith
There's no way to set up the fixturing to give you a specific dimension, you have to guess, make a cut, measure it, and see if you need to tap the table/vise one way or the other. Accuracy in this case is down to how precise you are on the setup and learning how the machine reacts to different cut depths (if there's a lot of slop in the spindle/quill/headstock, making a cut can pull it farther in one direction depending on the type of cut you're making).
It's kinda like asking 'what's the accuracy on that hand file?' It depends on how much metal you take off! :)
comfy, I think he was trying to ask how bad the runout / slop / etc was. You brought that up earlier in the thread and I agree that it’s a valid concern… that said, there’s really no halfway on having tight tolerances. Either you’ve got what you need or you don’t. If OP can’t spring for the best, the HF may be a great option.
The slop or runout doesn't matter. Holding the workpiece at a stable, fixed point relative to whatever space the spinning tool bit occupies is what will determine the accuracy. Even if the shaft is bent and has lots of runout it still spins the tool bit in the same size circle every time it comes around. Machining round parts, the accuracy depends on being able to rotate the workpiece in a concentric circle, not the machinery.
First step, the four holes are the reference point for the first cut. The accuracy of where you put the holes and their size and their concentricity will determine the accuracy of the outer circle. It's like tracing a pattern. Any flaws in the master will transfer to the copies.
The starting points for the 4 holes were in the right places, the scribed circles were not! The holes are the part that matters.
Tapping the table left or right moves the fixturing pin closer to or farther from the tool bit. There's no measuring scale like on a feed screw on a X-Y table or a lathe tool post. You just have to tap, make a cut, measure, and see how much it moved and whether you need another tap.
Now that the outer bore is the right size, and round, the center locating holes are no longer needed. The outer part of the holes will take over the job of being the master for making the rest of the cuts. (also note I replaced the previous layer of masking tape on the aluminum angle with packing tape, to reduce friction)
The flashing left over is thin enough this part was cut freehand, it was very easy to cut away the leftovers without cutting into the finished part.
Again, another step is cut, using the un-cut part as the locating point for the clamped pins. If the surface used as the reference point is round and the right size, the new cut will be as well.
It's all about the fixturing, and being able to plan out a series of operations that will give you something accurate from the previous step to use as a reference for the next one.
There's another very important point: how you set up this stuff matters. A lot.
This is correct. See how if the workpiece moves away from the pins, it will cut LESS? And by pushing it up against the pins it'll cut more?
Same here, just it's a cut on the ID instead of OD. If it moves away from the pins it cuts less.
Same here.
Now, see this? This is WRONG! WRONG WRONG WRONG DO NOT EVEN TRY THIS, it will bind up and either fling the piece across the room or break the bit or maybe both. You absolutely MUST have it set up so you can slide the workpiece away from the pins (& the bit) while you reposition your grip. If it cuts deeper when the piece moves away from the pins, you will have a very bad not good day.
Very interesting, Comfy. This is the kind of thing that fascinates me. My imagination is so convoluted and complex that I can’t imagine a way to overcome lack of machinery and high end ($$$:money_mouth_face: tools. Your solutions remind me of the simple old world solutions that people come up with in my wife’s home country of Costa Rica. I often see how people manufacture of repair things there and wonder why they have something set up in that way until I see what they are doing and I am dumbstruck by their genius of simple solutions to complex problems. I envy that ability to cut out the noise and identify the problem and come up with a solution that is simple and robust. I was looking at rotating tables but the cheapest one that I could find was for $250 on Craig’slist and was a huge version of one of these.
Perhaps or maybe better, please consider posting a thread of how to machine like comfychair. It would be a big help for those of us on a budget that lack a practical imagination.
Well, each situation requires its own novel solution. It's like, how do you give instructions on how to be creative, how to repurpose 'found' objects to solve a problem? I used that 4-up bezel-thing as an example, just because that was one that took me a good bit of thinkin' before I hit on the solution, mostly because I was trying to make it more complex than it really was. To cut something round, you only need a stable & accurate reference point (it only varies a little whether it's on the inside or outside of the workpiece); in that case it was as simple as using the four center holes that would later be cut out and discarded.
That fixture thing I made to hold the stainless pins I use for probably better than 90% of everything. It's just two pieces of 1/8" thick aluminum angle, clamped in the vise, and then six holes drilled only partially through, so the pins don't fall out the bottom when the vise is loosened, and to hold the pins at the same height even if you move the pins to a different set of holes. I have a bunch of the long stainless pins (scavenged from old CD-ROM drives, they're the guide rails the laser pickup slide on), and cut them to length (height) if I don't have something already made up that will work. You could just as easily use various diameter TIG welding filler rod, it's available in about every material you could imagine - stainless, titanium, inconel, aluminum, silicon bronze, etc.
For milling a flat surface on top of something with an endmill it's a lot harder, the cuts have to be really shallow or else it bites and flings stuff across the room. Whenever possible, especially since a lot of these parts are small and that puts soft fingers uncomfortably close to very sharp fast-spinning metal, I try to bolt the object down onto a larger baseplate that gives a more stable surface to slide around while making the cut. For something like a pill that's taller than it is wide, that helps a LOT.
That was done without being clamped down except to the square baseplate, just sliding the baseplate around under the endmill. Taking very very shallow cuts (no more than about .010"), measuring, then raising the table a tiny bit and going at it again until it's close enough to finish off with a file and then wet sanding.
