I had similar erratic behavior with both the irlm 2502 and lfpak 56 when using them without the gate resistor and above a certain current level. The gate resistor resolved this in both cases. It may be something to do with board geometry or who knows what since as far as I’ve heard it varies from board to board or FET to FET.
I tested the AOD510 & STD95N2LH5 on a 17DD v2.0, clicky switch (added to the side of my test battery box), single tame ICR 18650, test LED was triple XPG2 (parallel) on a CPU heatsink. I only tried them as drop-in replacements for the 70N02, so same 130/12k resistors, didn't try either FET without the resistors.
On paper, the AOD510 should be better at everything. Lower Rds(on), lower total gate charge, etc. Don't know why it wouldn't cooperate. I still have them, I may get back to it when I have some spare time.
Are you guys noticed how fast OSHPark has gotten these past few weeks? I don’t know it they were just going slow cause of makers fair and now that’s over or what happened but I’ve got shipping notices for boards I ordered just 8 days ago, used to it was 14+ days.
Doubt anyone from OSHPark is reading this thread or anything but if they happen to see this thanks for the hustle lately!
I created a driver for Roche F6 or Roche X3 if anyone would like it. 70N02 mosfet DD side switch. I would just prefer someone took it for a spin before I posting it in general.
Since 70N02’s aren’t current avaliable on eBay what’s the next best option from a US based seller?
See post #853
I suspect that nobody who needs to build drivers and has the capacity to determine what will work well has run into this yet. Many of us have some 70N02 stockpiled for now, so no need to buy more FETs and test them… comfychair went as far as to do a quick test and the driver failed to operate properly with other candidates.
Possibly adjusting the gate pull up/down resistors will solve the problem with AOD510, if so then it looks like a good choice.
70N02 FET’s come up whenever I do an eBay search.
I made a 3xAA in series battery-holder, using the Oshpark boards mentioned in the OP, and did some tests on it, thread here:
Any board I buy, the next day they are on the production board and sent to fab within a day or two…they are probably soon going to get backlogged and/or going to have to make several production runs a day or something
Good for us…they keep pumping out the purple board goodness
Just ordered 3x BLF SRK XP-G2 3 channel boards I special built for my 3*XP-G2 SRK rebuild
(going to try to make the SRK into a semi-thrower and push XP-G2’s a little harder than 1500mA per channel but wanted independent channels to prevent thermal runaway (just in case)
[Huge thanks to Mattaus for pulling my head out of my butt and pretty much designing the board, I just cleaned it up a teeny bit)
None in the USA though. I assume Cereal is getting tired of sitting on however many SRKs he’s got now and wants them modded up and out the door :-p
Just because it's called a '70N02' doesn't mean it'll have the same specs and work in the same way as the Vishay 70N02. Even Vishay's own replacement for the discontinued 70N02 has wildly different specs.
I’ve started work on a QX5241 based 17mm driver. 17mm QX5241 5Amp 1-4 LED 2-4s Li-Ion Buck driver, WIP - I'm back in the saddle.
Bump for RMM. Rich has boards for us now.
Hey guys, gals, and any who are mixed or unsure, I’ve updated the op with some new links but I’ve noticed some links to other Oshpark projects in a few other threads and don’t know whether I should add them. I might miss them if they aren’t posted here so if you want them listed then let me know either by pm or posting here.
Thanks, RBD
Just an FYI WarHawk and I are both using his SK68 boards without issue, of course clear it with him but these ar no longer “untested” and again only my opinion but are ready for use.
ETA: one more thing, both WH and wright have made some pretty useful contact boards for me which I’m already using both of, a 26mm contact board and a 22mm adapter ring (the adapter ring is a really useful / wide application piece). 26mm is the size for both the TR-3T6 and 9XT6. I am using wright’s adapter ring in stock forum for a 22mm pill w/ 17mm driver but with a little sanding it’ll fit several size pills and / or drivers.
Thread here-
Thanks for bringing that up Cereal_killer, I’d already forgotten to tell RBD about those adapters. Can you tell us specifically which ones adapter rings you’ve received? Do they look exactly like the previews? Do you mind posting pics / measurements in your request thread? I want to make sure the toolpaths were followed as they were in the Gerbers.
Off to work on a Saturday. I’ll post the links in the op this evening.
I really like wights open contact ring…very very versatile
Oh and Cereal_killer my SK68 board the first one I built I am not sure either
A. I compiled DrJones luxdrv with ramping only incorrectly [initial compile I didn’t change the “ramping” number to 1…so it would throw off something] or
B. I have bad 7135’s due to the fact it won’t reset, flickers, locks up acts all crazy
I haven’t successfully tested a board completely yet…if you are confident with it…then give the thumbs up on it…I just can’t verify yet…glad it’s working
Wasn’t it said somewhere that 7135’s won’t go as low? If you go for a real low moon they act up? And also something about the PWM rate? Might check that out as well. Sorry I don’t have more pertinent information, but I am not using anything it pertains to and well, my memory is kept in a minnow bucket with oversized flow holes.
