Group Buy for the GearBest Ultrafire F13 - Closed?
clicking on the link gives me this, 404 ERROR - NOT FOUND!
Has anyone else gotten this error?
This is the url at the top of the page, http://www.gearbest.com/led-flashlights/page_not_found
This link?
http://www.gearbest.com/led-flashlights/pp_5499.html
It works for me.
Order W1405200719495112
Order Date: 05/20/2014 22:19:49 PM
“Tracking Details >> SGxxxxxxxxxx9276
Not found .”
This is the url I get when I click on the link you posted.
Hello strongest2004,
I just checked your order#, since you selected Flat Rate Shipping which is unregistered mail, no tracking number is available with this order therefore the shipping progress cannot be traced online.
However I’m delighted to inform you that your order is on its way. The standard delivery time will be around 15-45 business days after dispatch if there are no delays. Please don’t worry,the package can reach you in due time. Thanks.
Most likely something is wrong on your end. Possibly something on your computer is modifying URLs. Try a different browser.
Link works fine for me.
Note, I am signed in to the site; it would not work for me if I weren’t signed in there.
The link that wight provided (which is the same as the one in the OP), works for me:
or, you can go to their home page and put:
ultrafire ceee xm-l
in the search box (yes, “Cree” is misspelled).
Really? I tried it without being signed in to GB - it seemed fine.
musket3 wrote:This is the url
I tried all 3 of my browsers, firefox, chrome and IE. None work, everything else works fine on my computer.
Then I tried this,
ultrafire ceee xm-l
This worked, search for ultrafire ceee xm-l, and brought up 1 light, then when I clicked on the light I got the error message again. I am signed in to my account on their web page. I give up.
I know it has a 20mm star, the reflector centering ring is quite thick so I don’t think a noctigon/sinkpad thickness will be an issue if you either use a thinner centering ring or thin it down a bit…
Noctigons and Sinkpads are thinner, not thicker, than standard aluminum MCPCBs.
All of the 16mm and 20mm aluminum stars I have are thinner than any Noctigon or Sinkpad I have.
Just sayin...
Link works for me without being logged-in.
I seem to have lots of thicker ones. I think that the aluminum stars I have from Illumination Supply and SinkPAD are all thicker than my copper Noctigons, but on the other hand the inexpensive Chinese stars are probably thinner than those. I have no idea what’s in the F13 head, I haven’t removed the MCPCB yet. My bad :frowning:
That is might weird :(…
I’ve seen things like that happen if I am pointing to some incorrect DNS server, or if the browser has the proxy setting wrong.
Have you tried clearing your browser’s cache? That might help also.
As per our offline discussions which you affirmed, I will wait only for a max of 40 days after my payment was placed. If I don’t have my order by that date, I will file for PP dispute already.
Thank you.
I had placed a different order on 4/20 that arrived 5/30, I think it was.
No surprise, stuff happens.
My order for this light was on 5/16.
I’d have paid for tracking if I wanted to be able to complain about delays.
I didn’t.
Sometimes delays happen and no one can explain.
I bought quite a few of these in two shipments. The second shipment has arrived. In it there were two different drivers. Some had no mode memory, always starting on high after being off for about five or six seconds with tailcap measurements of 2, 1.45 and .75 amps. The other had next mode memory with tailcap measurements of 2, .75 and .3 amps. The pencil trick worked to get this light to always start on high after about 5 seconds.
Did the ones with the different drivers also have different labelling? Wasn’t the original one for this GB a “SkyFire” or something, and then they switched to “Ultrafire” (now)? Maybe that was the reason for the driver differences in yours?
