May 16 departed from sorting Hub. WTF?...It's been a month since it was originally mailed. That's what the shipper told me! Am I bitching? Nahhh, I'm not bitching.
Expand
Translate | Aim Language:Not Translated
Group
Copy
Re Track Error
Results:
Not Found(0) / Transporting(1) / Pick Up(0) / Delivered(0)
Lens is dirty, reflector is dirty and spot is horrible. Led is centered correctly. I think problem is reflector profile. It doesn’t want to work correctly with any led (XM-L2, XP-G2) even with thin isolution gasket.
What I should to do? demand new one? or for refund?
At now Tmart offer me $14 refund, but as you konw, is impossilbe to buy reflector for HD2010 so money don’t give me any profits, I still will have bad flashlights with horrible spot.
after copper braiding springs, and using thick wires from the driver to the led, my tangsfire seem to be at around 4.5A, at least for the first seconds, didn’t test longer.
I received the replacement light and it is better than the first. This driver draws over 3A at 4V on my bench power supply, and they used a much thinner spacer under the reflector making for a tighter, cleaner hotspot.
Sorry to say This has to be the lousiest shipping in the WORLD ! Friggin' around for 2 months with this replacement thing. i'M GLAD TO GET A REPLACEMENT BUT GDSOAB JUNE 3 STILL IN FRIG'N SWEDEN
Product & Tracking Information
Postal Product:
Features:
Registered Mail™
DATE & TIME
STATUS OF ITEM
LOCATION
Origin Post is Preparing Shipment
We have received notice that the originating post is preparing to dispatch this mail piece.
I received my replacement last week: quality is worse than first one that I received, LED is old XM-L (first one was XM-L2) but the driver is correct
They used silicone adhesive under emitters on both of them pain to remove…
Finally got my light yesterday. Haven’t really inspected it yet since I’ve lost the excitement for the light but the Oring at at the body tube to head was broken. I’ll need to find a replacement for that…once I feel like working on this light.
Originally ordered 3/22 and finally recieved what I ordered 6/14, 8 days short of 3 months.
My replacement came in yesterday, light has a xml in it and a 17 mm size driver. Draws 1.5 amps at tail on high , light is black in color and has Cree xm- lt6 written on it . Light is noticeably less bright than the 1st. Whines bad on high , looks pretty nice though, emitter is glued in with some rubbery clear stuff, maybe I’ll try my luck with my first mod attempt :Sp
Mine is broken now. Changed wires from driver to led, and that improved the amperes.
The new wires were much stiffer though. yesterday when i was going to try my new 26650 in it, nothing happened. After some troubleshooting i saw that the transistor (?) Right between the 2 led wires had come almost loose from the driver board, due to the stiffness from the new wires, “bending” the transistor off the board.
I don’t think it’s repairable, but haven’t tried anything yet.
Thinking about what i should replace it with, another east 092 driver, or perhaps i should try stacking a couple extra 7135 on a 2.8A driver.
