I made a 3xAA in series battery-holder, using the Oshpark boards mentioned in the OP, and did some tests on it, thread here:
Any board I buy, the next day they are on the production board and sent to fab within a day or twoā¦they are probably soon going to get backlogged and/or going to have to make several production runs a day or something
Good for usā¦they keep pumping out the purple board goodness
Just ordered 3x BLF SRK XP-G2 3 channel boards I special built for my 3*XP-G2 SRK rebuild
(going to try to make the SRK into a semi-thrower and push XP-G2ās a little harder than 1500mA per channel but wanted independent channels to prevent thermal runaway (just in case)
[Huge thanks to Mattaus for pulling my head out of my butt and pretty much designing the board, I just cleaned it up a teeny bit)
None in the USA though. I assume Cereal is getting tired of sitting on however many SRKs heās got now and wants them modded up and out the door :-p
Just because it's called a '70N02' doesn't mean it'll have the same specs and work in the same way as the Vishay 70N02. Even Vishay's own replacement for the discontinued 70N02 has wildly different specs.
Iāve started work on a QX5241 based 17mm driver. 17mm QX5241 5Amp 1-4 LED 2-4s Li-Ion Buck driver, WIP - I'm back in the saddle.
Bump for RMM. Rich has boards for us now.
Hey guys, gals, and any who are mixed or unsure, Iāve updated the op with some new links but Iāve noticed some links to other Oshpark projects in a few other threads and donāt know whether I should add them. I might miss them if they arenāt posted here so if you want them listed then let me know either by pm or posting here.
Thanks, RBD
Just an FYI WarHawk and I are both using his SK68 boards without issue, of course clear it with him but these ar no longer āuntestedā and again only my opinion but are ready for use.
ETA: one more thing, both WH and wright have made some pretty useful contact boards for me which Iām already using both of, a 26mm contact board and a 22mm adapter ring (the adapter ring is a really useful / wide application piece). 26mm is the size for both the TR-3T6 and 9XT6. I am using wrightās adapter ring in stock forum for a 22mm pill w/ 17mm driver but with a little sanding itāll fit several size pills and / or drivers.
Thread here-
Thanks for bringing that up Cereal_killer, Iād already forgotten to tell RBD about those adapters. Can you tell us specifically which ones adapter rings youāve received? Do they look exactly like the previews? Do you mind posting pics / measurements in your request thread? I want to make sure the toolpaths were followed as they were in the Gerbers.
Off to work on a Saturday. Iāll post the links in the op this evening.
I really like wights open contact ringā¦very very versatile
Oh and Cereal_killer my SK68 board the first one I built I am not sure either
A. I compiled DrJones luxdrv with ramping only incorrectly [initial compile I didnāt change the ārampingā number to 1ā¦so it would throw off something] or
B. I have bad 7135ās due to the fact it wonāt reset, flickers, locks up acts all crazy
I havenāt successfully tested a board completely yetā¦if you are confident with itā¦then give the thumbs up on itā¦I just canāt verify yetā¦glad itās working
Wasnāt it said somewhere that 7135ās wonāt go as low? If you go for a real low moon they act up? And also something about the PWM rate? Might check that out as well. Sorry I donāt have more pertinent information, but I am not using anything it pertains to and well, my memory is kept in a minnow bucket with oversized flow holes.
Sweet. Looks like they came out more or less as intended!
Thanks for posting the pics.
Wow,
very nice. Hardly can wait to get mine. Shipped the other day, might take about 2 weeks now.
Thanks for the pictures, nice to see that the layout seems to work well.
Yeahā¦I think it was my compile, I didnāt change the location of the ramping in the code and I used fast PWM
Cereal_killer did a few videoās for me on the next re-compile and it looked as if it worked on his builds, ramping was clean and worked as compiled
(if he wantās he can post links) Itās a SK68 with 100% variable modes w/ memory
I just have to rebuld my driver and give it a shot, using the slow PWM he reported it ramped smoothly (fast PWM went all wonky)
Way cool!
A little cleanup of the inner tabs and a few shots of solder and BLAMOā¦instant 22mm Nanjgā¦NICE!
hi RBD, this battery-carrier is therefore no longer untested, so the the OP might be updated for these triple AA boards??
Hereās a few installed picās.
I was hoping the added height would make it so I could use a normal size spring in this balder SE2 but not quite.
I think the op is now up to date.
