Group Buy for the GearBest Ultrafire F13 - Closed?
I tried without the centering last night, too. I was surprised how much the reflector could drop and disappointed with the beam, but then I thought it might be very helpful with a de-domed emitter. Everyone complains about not being able to get the reflector low enough after de-doming, maybe this will turn out to be a plus.
I don’t know yet, as I haven’t tried that. A bit of a time soldering still (eye surgery a couple of months ago), so I’m trying to take things easy, but I did just do the solder wick on the tailcap, and after that:
Battery 1: 1.26 amps => 1.7 amps => 2.1 amps
Battery 2: 1.69 amps => 2.1 amps => 2.6 amps
FYI, Battery 1 is an old laptop pull (dark blue wrap) and Battery 2 is a “20R” battery.
Also, I’m just using the normal meter leads, so the tailcap current is probably higher, right?
I know you all normally recommend doing the solder wick on the springs, but this is the 1st time I did it, and I’m kind of amazed at the difference it made :)!
What did you do to insulate the reflector (prevent it from shorting)? Did you put tape on the end?
I keep thinking that an MT-G2 would fit nicely in that reflector opening, but don’t have an extra one at hand…
It was just a quick look to see what difference removing the centering ring would do so I didn't insulate it. Not a problem with the small reflector and 20mm star. The opening is only 7mm, an MT-G2 needs 9mm just for the dome.
I was thinking that the F13 reflector has that rather large flat area around the emitter area, and that the opening could be opened up a few mm to fit an MT-G2…
Not too difficult to get 9mm for the dome, might be tricky if you want to set down over the entire square package.
I have another (different) light that i put an MT-G2 into, where the reflector opening just barely fit the dome (the entire dome, but not the die), and that has a very nice beam… no rings, etc., so I think that the opening wouldn’t have to be large enough for the die, just the dome. Unfortunately, as I said, I don’t have a spare MT-G2 at this time to try it though…
Let’s keep our terms straight. You two are referring to the ‘package’. The ‘die’ is something else.
Sorry, you’re right :)…
Right, edited to prevent future confusion.
The problem with just clearing the dome is the that the reflector can cut into the soft surface.
Finally brokedown and ordered. Paid $7 after GB points :slight_smile:
Ordered one, this will be a hold me over and a comparitive flashlight for when I get this Xpower 26650 @FT
Has anyone tried to fit an mt-g2 in the light?
Did some mods to mine yesterday.
Recap mine was pulling 2.11amps on high with a KingKong 26650 INR.
I was disappointed with the throw and colour despite the good amp draw.
First thing I did was the pencil mod which I hasten to say worked brilliantly. I then moved the red wire to the output1+ with no other changes.
It was now pulling 2.86amps on start up and just over 3.0amps after about 20 secs.
The beam was still horrible though.
I then removed the reflector and the driver and NOTE the led just falls out. There is nothing, no thermal compound or anything holding it in place. The only thing I could see was something that looked like a few drops of something oily.
Next step was to fit an XP-G2 NW on a noctigon. Anyone else doing this I highly recommend using a 20mm star. I only had a 16mm. In order to get the reflector to clear the solder points I have to file the square edge off of the outside of the reflector base. Sadly it still just fouls the solder points, but does allow the white centering ring to seat on the star now. Ideally I’d have liked not to use the white plastic centering ring.
I beefed up the wire (20 or 22 gauge I think) and resolder the driver.
It now pulls 2.46amps on high (showing that an XP-G2 does indeed pull less amps than an XM-L on the same driver, not sure why, but have seen this on 3 other XP-G2 installs).
The colour is obviously way better and the beam is improved. Sadly I didn’t get the XP-G2 perfectly centered, another reason to use a 20mm star if you have one. But throw is massively improved, it now easily out throws my Imalent DDR2 XM-L2, which it was nowhere even close too before.
And oddly the white centering ring seems to work quite well with the XP-G2 giving an almost XM-L sized hotspot.
Overall I think the light is much improved for these changes, which really has only been a LED & star plus moving some wires about.
Thanks OL for the group buy.
I was fiddling with the reflector last night. The focal point seems to be ~3mm below the base. Can anyone confirm that? That's why they use such a tall centering ring.
I had tried removing the centering ring and substituting a 3mm thick o-ring. The beam was very floody. At ~40m, shining into a tree it was almost indistinguishable from my Convoy S6 w/XP-G2 S2 1B @3A, side by side.
Here is the link
Coupon code has been extended: LL0101701 the expiration date is JULY 9th.
nice and thank you for the review you made on GB site.
These are great lights…ready for either basic “tweaking” mods to all out barn burner mods
So far I have just done a very modest mod and this thing chucks some light, even using el-crapo and probably wore out laptop pull 18650’s w/ adapter
Recommended basic “tweaks”
  • pencil lead next mode memory fix
  • move wire to other side of resistor bridge pad for extra power to emitter
  • heatsink compound under star
  • replace the large centering ring (or shave it down)
  • solder braid on springs
Would I be able to put in the 20mm FET driver or will it slip through?
Still waiting on mine.
