Any board I buy, the next day they are on the production board and sent to fab within a day or two…they are probably soon going to get backlogged and/or going to have to make several production runs a day or something
Good for us…they keep pumping out the purple board goodness
Just ordered 3x BLF SRK XP-G2 3 channel boards I special built for my 3*XP-G2 SRK rebuild
(going to try to make the SRK into a semi-thrower and push XP-G2’s a little harder than 1500mA per channel but wanted independent channels to prevent thermal runaway (just in case)
[Huge thanks to Mattaus for pulling my head out of my butt and pretty much designing the board, I just cleaned it up a teeny bit)
Just because it's called a '70N02' doesn't mean it'll have the same specs and work in the same way as the Vishay 70N02. Even Vishay's own replacement for the discontinued 70N02 has wildly different specs.
Hey guys, gals, and any who are mixed or unsure, I’ve updated the op with some new links but I’ve noticed some links to other Oshpark projects in a few other threads and don’t know whether I should add them. I might miss them if they aren’t posted here so if you want them listed then let me know either by pm or posting here.
Just an FYI WarHawk and I are both using his SK68 boards without issue, of course clear it with him but these ar no longer “untested” and again only my opinion but are ready for use.
ETA: one more thing, both WH and wright have made some pretty useful contact boards for me which I’m already using both of, a 26mm contact board and a 22mm adapter ring (the adapter ring is a really useful / wide application piece). 26mm is the size for both the TR-3T6 and 9XT6. I am using wright’s adapter ring in stock forum for a 22mm pill w/ 17mm driver but with a little sanding it’ll fit several size pills and / or drivers.
Thanks for bringing that up Cereal_killer, I’d already forgotten to tell RBD about those adapters. Can you tell us specifically which ones adapter rings you’ve received? Do they look exactly like the previews? Do you mind posting pics / measurements in your request thread? I want to make sure the toolpaths were followed as they were in the Gerbers.
I really like wights open contact ring…very very versatile
Oh and Cereal_killer my SK68 board the first one I built I am not sure either
A. I compiled DrJones luxdrv with ramping only incorrectly [initial compile I didn’t change the “ramping” number to 1…so it would throw off something] or
B. I have bad 7135’s due to the fact it won’t reset, flickers, locks up acts all crazy
I haven’t successfully tested a board completely yet…if you are confident with it…then give the thumbs up on it…I just can’t verify yet…glad it’s working
Wasn’t it said somewhere that 7135’s won’t go as low? If you go for a real low moon they act up? And also something about the PWM rate? Might check that out as well. Sorry I don’t have more pertinent information, but I am not using anything it pertains to and well, my memory is kept in a minnow bucket with oversized flow holes.
very nice. Hardly can wait to get mine. Shipped the other day, might take about 2 weeks now.
Thanks for the pictures, nice to see that the layout seems to work well.
Yeah…I think it was my compile, I didn’t change the location of the ramping in the code and I used fast PWM
Cereal_killer did a few video’s for me on the next re-compile and it looked as if it worked on his builds, ramping was clean and worked as compiled
(if he want’s he can post links) It’s a SK68 with 100% variable modes w/ memory
I just have to rebuld my driver and give it a shot, using the slow PWM he reported it ramped smoothly (fast PWM went all wonky)
WORK IN PROGRESS: "Medusa" SRK Replacement PCB: http://oshpark.com/shared_projects/NuBPKgTp
Complete all in one package replacement PCB for SRK style lights.Not sure why I'm posting this. Maybe someone else will be interested in trying it out. I figure it'd look cool having the electronics all exposed in the face of the lights, and multiple different lights for different uses.
You will have to use the stock driver PCB as a dummy contact board. Highly recommended to add a heat sink to the rear of this board. Given the height of the topics chosen this board could be stacked on top of aluminum or similar to bring the optics closer to the SRK lens.
4 XP footprint emitters driven via 70N02 FET through Carclo 24mm quad optic (board pre-drilled for this optic).
Single XP footprint emitters driven via IRLML2502 FET through Ledil Lisa 2 optic(board pre-drilled for this optic).
3 XQ footprint emitters driven via 2x7135 regulators per LED. XML Reflector 12mm in diameter (no mount holes for a reflector).
There are two LED+ (BATT+) connections on the board but they are electrically the same. I just couldn't get the traces down for one solder point so had to split it. Both LED+ pads connect to BATT+.
MLCR doubles as the SW+ pad.
Controlled via PIC16F1825 in TSSOP-14 package. Debug/programming points included. Designed to use ttrev3's MLEDv2 firmware without modification: http://tterev3.blogspot.com.au/2014/04/meld-v2.html
I had a link to the firmware but cannot find it right now. The single XP emitter is connected as if it were the UV emitter, while the quad XP emitters are connected as if they were the white emitter in the WRGB array of the original. Red, green, and blue are all connected as normal.
I plan on using a medium flood optics with 4 nichia 219 emitters for the quad, dedomed cool-white XP-E for the single emitters for throw, and then regular XQ R,G,B for the reflector.
Should be a versatile light for camping. I was going to use a UV emitter in place of the single emitter but I couldn't find a reliable source for a cheap UV emitter. That and I think throw will be more useful.
