Hikelite
(Hikelite)
July 16, 2011, 8:03am
6
http://www.cnqualitygoods.com/goods.php?id=1150
http://www.cnqualitygoods.com/goods.php?id=1145
I have finally found out what's the reflector size for these two flashlights, since no one @cnqualitygoods is willing to answer my e-mails.
It's 51mm wide and 30mm deep. I sure looks shallow and probably that's causing that outer ring.
1) UniqueFire UF-2180: manafont $58 Shipped
2) UniqueFire UF-2170: Manafont $58 Shipped
3) 1&2 26650 Host: cnqualitygoods $33 Shipped
4) 1&2 26650 XML: cnqualitygood $60 Shipped
5) Maelstrom S12: 4sevens $135 Shipped
6) TorchLite Host: gigainternational $50 Shipped
7) Palight BG-SST50: manafont.com $178.50
8) 2X26650 Host:cnqualitygoods $48.60 Shipped
9) 2X26650 XML: cnqualitygoods $68.60 Shipped
10) 1&2 26650 XPG-R5: cnqualitygoods $48 Shipped
11) Big Bruiser 3 XML: elektrolumens $ 260 Shipped
12) Titainium P60 26650 Host:candlepowerforums $486
Hikelite
(Hikelite)
July 18, 2011, 2:11pm
9
Who feel that this 1&2 26650 Host: http://cnqualitygoods.com/goods.php?id=114
or http://cnqualitygoods.com/goods.php?id=1077
has shady pictures but is interested in such a host, check the link below for better pictures
http://item.taobao.com/item.htm?id=10547709791
okwchin
(okwchin)
August 7, 2011, 4:58pm
10
Switch Type:
No switch, put in battery & the flashlight will work
Im guessing this is a twisty, lol. http://www.dealextreme.com/p/fandyfire-bt-qs88-xm-lt6-waterproof-1-mode-1000lm-white-led-flashlight-2x26650-2x18650-4x123a-91661
I LOVE the 18650 adapters though.
Tally-ho
(Tally-ho)
August 7, 2011, 6:16pm
11
The pill / heatsink looks good even if it lacks of mass / volume compared to the one of the original JM07 (on left)
So I prefer the "original" TorchLight / Shadow JM07 and idealy I would buy the one with the bigger head:
http://item.taobao.com/item.htm?id=5538270055
http://item.taobao.com/item.htm?id=5980690322
The problem is to know if the 55mm reflector for MC-E will "work" with an XM-L.
Hikelite
(Hikelite)
August 7, 2011, 6:52pm
12
I do not know if the XM-L would benefit from such a flat area around it, like the reflector of the MC-E Torchlite with 55mm head and it appears to be heavy OP.
If you don't mind the double battery format this would make a better host in my opinion:
http://www.aliexpress.com/product-fm/315682287-led-flashlight-shell-torch-for-SST-90-T6-by-two-26650-batteries-wholesalers.html
Tally-ho
(Tally-ho)
August 8, 2011, 5:00pm
13
Yes, I seen this host a few days ago when I was searching 26650 flashlights but I didn't seen it anywhere else probably because it was discontinued.
(I seen one like this in Taobao but was not sure if it was new or used.)
"Sorry, this item is no longer available! "...
Nice! do you know if the body detach to run in single 26650?
Doesn't look like it does.
2100
(2100)
August 18, 2011, 5:56am
17
I'm waiting for the new Shadown lights from CNQ. Supposed to be very power, very good. Hope they are of Jetbeam quality.
What that extension under the light then??? Hmmmmm
[IMG]http://i912.photobucket.com/albums/ac323/vinhnguyen54/421.jpg[/IMG]
<a href="http://s912.photobucket.com/albums/ac323/vinhnguyen54/?action=view&current=421.jpg" target="_blank"><img src="http://i912.photobucket.com/albums/ac323/vinhnguyen54/421.jpg" border="0" alt="Photobucket"></a>
Also doesn't look like the Voltage range would handle 1 battery
[quote]
Power 6~8.4V 2x26650 (not included)
[/quote]
jonhobart
(jonhobart)
August 23, 2011, 1:52am
20
Anyone actually purchase either the UF-2170 or the UF-2180? Curious to see beam shots and find out if they are equivalent or essentially the C8 that is highly recommended on BLF, but with the 26650 battery.
Tia.
Hikelite
(Hikelite)
August 28, 2011, 1:03pm
21
Other details from TaoBao:
Hikelite
(Hikelite)
August 28, 2011, 1:18pm
22
This light definitely exists in 1x26650 format. In this photo the 2x26650 tube is in the background.
Priced @ $33
The 2x26650 version is sold for $36 by the same seller.
Shipping is $1.5 in China. :)
Fightin14
(Fightin14)
September 19, 2011, 5:35pm
23
Is there anyone here that has actually seen/used the shadow? I want one but I am not willing to buy the batteries and a new charger on a whim for one light.
yavi
(yavi)
September 19, 2011, 6:59pm
25
Just in case you did not try, 3AA hosts are normally compatible with 26650 as far as I have seen, the closest I got is a zooming from taobao made for 4AA but this one could have a 32600/32650 instead.
*I am only talking about sizes, drivers might not be compatible and should be replaced.
