Let’s keep our terms straight. You two are referring to the ‘package’. The ‘die’ is something else.
Sorry, you’re right :)…
Right, edited to prevent future confusion.
The problem with just clearing the dome is the that the reflector can cut into the soft surface.
Finally brokedown and ordered. Paid $7 after GB points
Ordered one, this will be a hold me over and a comparitive flashlight for when I get this Xpower 26650 @FT
Has anyone tried to fit an mt-g2 in the light?
Did some mods to mine yesterday.
Recap mine was pulling 2.11amps on high with a KingKong 26650 INR.
I was disappointed with the throw and colour despite the good amp draw.
First thing I did was the pencil mod which I hasten to say worked brilliantly. I then moved the red wire to the output1+ with no other changes.
It was now pulling 2.86amps on start up and just over 3.0amps after about 20 secs.
The beam was still horrible though.
I then removed the reflector and the driver and NOTE the led just falls out. There is nothing, no thermal compound or anything holding it in place. The only thing I could see was something that looked like a few drops of something oily.
Next step was to fit an XP-G2 NW on a noctigon. Anyone else doing this I highly recommend using a 20mm star. I only had a 16mm. In order to get the reflector to clear the solder points I have to file the square edge off of the outside of the reflector base. Sadly it still just fouls the solder points, but does allow the white centering ring to seat on the star now. Ideally I’d have liked not to use the white plastic centering ring.
I beefed up the wire (20 or 22 gauge I think) and resolder the driver.
It now pulls 2.46amps on high (showing that an XP-G2 does indeed pull less amps than an XM-L on the same driver, not sure why, but have seen this on 3 other XP-G2 installs).
The colour is obviously way better and the beam is improved. Sadly I didn’t get the XP-G2 perfectly centered, another reason to use a 20mm star if you have one. But throw is massively improved, it now easily out throws my Imalent DDR2 XM-L2, which it was nowhere even close too before.
And oddly the white centering ring seems to work quite well with the XP-G2 giving an almost XM-L sized hotspot.
Overall I think the light is much improved for these changes, which really has only been a LED & star plus moving some wires about.
Thanks OL for the group buy.
I was fiddling with the reflector last night. The focal point seems to be ~3mm below the base. Can anyone confirm that? That's why they use such a tall centering ring.
I had tried removing the centering ring and substituting a 3mm thick o-ring. The beam was very floody. At ~40m, shining into a tree it was almost indistinguishable from my Convoy S6 w/XP-G2 S2 1B @3A, side by side.
nice and thank you for the review you made on GB site.
These are great lights…ready for either basic “tweaking” mods to all out barn burner mods
So far I have just done a very modest mod and this thing chucks some light, even using el-crapo and probably wore out laptop pull 18650’s w/ adapter
Recommended basic “tweaks”
- pencil lead next mode memory fix
- move wire to other side of resistor bridge pad for extra power to emitter
- heatsink compound under star
- replace the large centering ring (or shave it down)
- solder braid on springs
Would I be able to put in the 20mm FET driver or will it slip through?
Still waiting on mine.
22mm
But…there is a solution
Wasn’t sure since the shelf looked to be a little wider. Can I order just one of those complete?
The hole in the shelf is definitely >20mm, I measured. There is no one currently selling populated BLF 22DD boards. I don’t think anyone has received one yet, WarHawk-AVG only just shared the widened version 2 days ago. If you need one built up I’d talk to RMM - http://mtnelectronics.com. He’s already assembling BLF20DD drivers for $14-15 here. I would expect lead time on the bare boards from Oshpark to be at least 8 days.
Let’s not forget your awesome 22mm Nanjg style build
[image] [image] This driver is 22mm in diameter. It is sized specifically for the new monolithic-head (no-pill) F13 flashlights such as the Ultrafire F13. The retaining ring threads on top of the 7135 cases. The 7135’s on top of the board have a setback such that the cases should clear the ledge inside the head, although the tabs may not. This should ensure good ground contact. I used ~20.5mm for the ledge. On top of the board is space for the MCU, an SOD-123 package Zener diode, and a 0805 pa…
I contacted RMM and he told me if I wait a few weeks he can get some boards to build one for me!
Thanks for the help, and I will be looking forward to receiving this, if nobody beats me to it I’ll make sure to get some photos and numbers.
Sure. If you can’t wait and are able to solder a little you could always order a built BLF17DD or BLF20DD from RMM now and install it using an adapter ring as discussed in this thread. Take careful look at my shared projects on Oshpark to select the appropriate boards for you. The 26mm v11 is the most versatile (when filed down to various diameters), but the 22mm v9b will require the least work. You’ll get 3 boards when you order, so it’s up to you to figure out what works best for you.
Awesome, looks like I’ll get some of those now, I’m sure I’ll eventually find a use for three of them.
You all really do make sure no problem goes unsolved! Thanks!
