I got the blue one and the chrome/silver one I ordered a few days ago. Shipping (to the east coast U.S.) was SUPER fast, and darn, these little things are bright. Definitely a good deal!
I got my Smiling Shark SS-508. It has less lumens but better throw than the TrustFire, as one would hope. However it is the first Smiling Shark light that I have found not working properly out of the box. These are simple twisties with the edge of the body contacting the driver to switch them on. This one has the driver contacting the head. The threads are anodized, but imperfectly so. So it is on when screwed tight and intermittent when loose. I will have to file the edge of the driver. Nice looking. Slightly longer than the TF but very light. Very nice keychain attachment, except for a simple ring that looks weak and I will replace with my smallest keyring. The hook looks secure, but I might replace it with a fishing swivel attachment to be sure.
The driver consists of two resistors in parallel. At least that makes it clear how to increase the output.
Added: I have it working now. At first the driver came out and in easily, but it got stuck and I took the whole head apart, which is hard for the usual reason that there were no notches on the pill to unscrew it. The pill is a thin aluminum ring, cut out for the star, but the driver butts against the pill and fits snugly in the head.
It weighs only 20 grams.
yours is probably the best in that you wont kill it with a 4.2v li-ion.
anymore i wont even look at anything i cant use a common rechargeable in.
how good is the thermal path from led to body?
Thanks for the heads up. I think frying them might annoy me slightly. How would I know which I have? They both list CR123 and 16340 as options, but both also state working voltage is 0.8 - 3.6v. One from FT, one from Kaidomain. The KD one was $5 dearer.
The thermal path of the SS-508 is not as bad as in some cheap lights. It is the hollowest pill I have seen, just a threaded ring notched to fit the star, but it fits the star and the body both snugly so heat can get out. I suspect it would not be over-driven with a 16340 cell. If it were, one could replace the two surface mount resistors.
For unprotected Li ions, it seems important not to have a boost driver. With CR123as, the boost would allow using the battery till it is discharged more, but would decrease the efficiency.
Just received my three SS-508 from banggood. Color is nice, but they all have defects. Scratched and one has even some red dots. It was well packed in bubbles and tape to prevent movement so it’s not from shipping. Probably factory rejects, not ideal to gift/resale.
Very bright with li-ions for XP-E, measured 0,35 A with Lifepo and 0.75 A with Li-ion at 3,7V. One mode, direct Drive, no boost.
I have a few of those mini-01 Trustfire boost drivers (marked TF) in my lights (actually blf-versions of them, but only the firmware is different) and they run fine on li-ions, with the boost circuitry still working after having used li-ions (works ok on NiMh as well btw).
As an aside, the Aleto is not completely traffic proof. It fell out of my sons pocket when skateboarding, was run over god knows how many times breaking keys and the light. Still held its shape, mostly, but cant be opened and will not light. He did not notice it fall out, but when heading home retracing steps looking for them, he found the light and some broken keys.
Ok, not an blf-original, but blf-modified firmware. Once upon a time there was Rey, a I believe Singapore based seller who had connections with the Trustfire company. He arranged a group buy of Trustfire mini-01 lights with neutral emitter and customised firmware: higher pwm (~1000Hz instead of couple of hundred), no disco, 2%low, 25%med, 100%high, always start on low (same as now, it took ages to decide on the modes). I think many are still happy with the light that came out of that GB. Sad enough for me I never received the package. Separately I did buy four of those drivers from Rey, and still find them useful, they boost ok from 1.2V and better from 3V, and go direct drive on li-ions (2+ amps on xml from a 16340 was very good).
It would be awesome to make a blf boost driver from scratch, the challenge will be more than 1 led-amp from a NiMh
When I compare the weight of the Aleto to the TF, I would not be surprised if its the light that mutated roaches will fight over after WW3. Im not sure how much the battery helped the light weight Aleto hold shapeish but I assume the sweet smell is the lithium. I was going to use vice grips and a rag to try open it but I dont want to damage the ano .
The SMILING SHARK SS-508 was mentioned in the Deal Alert thread for a price higher than what I paid for it. I mention that here in order to conform to the no discussion rule there.
It seems to me that it is not really a deal, not only because I paid less, but because if I had really wanted to use it I would have preferred one of the other aluminum clones.
