That would be cool. You can’t start with flashlight parts but you could certainly do a conversion of something else if making your own stock is too complicated. Even a conversion wound involve quite a bit of work.
No - I’m going to make the stock from a lump of timber - that should be fairly easy. The trigger mechanism & barrel - not so easy!
Brass is much cheaper at the salvage yard and easily soldered & just a bit harder to braze(need a mapp torch minimum). I bought $30 worth of stuff for only $6 by weight.
Getting a bit more done - long weekend, should be able to put a good dent in it….
Diesel is good for plenty of low end torque… so a floody emitter fits the bill nicely. Subscribed …despite the Patrol part number.
Sorry - no Toyota’s at work that day….
…bump for today’s work…
Hey, you got the same sub $5 multi meter I got!
Ahhh, but does it have the modded probe wires & repaired trace on the circuit board from trying to measure a little more amps than it can handle? :bigsmile:
Looking good. A small spacer that fits in the gap on the lens retainer will prevent it being distorted where the screw goes through. It could also be the start of a mount for a handle or it could just be left the way it is and I'll shut up.
I’ll be doing something with the joint on the bezel, I just don’t know what yet… I’ve filed it up a little since that shot to even both the tabs up.
going to be a cool shoulder-fired light when its completed
Looking good.
Thanks guys, bump for today’s progress….
So many more intricate parts that I want to do…… time will tell.
Very cool build. I almost used that same reflector from FT. It seems to be a pretty good reflector.
Good recovery. The timber work turned out nicely.
It’s pretty thin, & mine came with a few small dings in it, but for a couple of bucks….
I used their ‘protective box’ shipping upgrade, as a few guys who tried to buy them ended up getting a squashed piece of alloy in their mailbox….
Tell me about it. I though mine was going to be simple. The devil, Murphy, Puck, and all their friends are hanging out in a club called “THE DETAILS”.
Bump for today’s work (end of post #4).
I like how people are incorporating wood into their builds, it gives flashlights, err… hand mortars, a whole new dimension. Keep it up, this is going to be a good one.
Cool, I really dig this build. Looking forward to more.
