OMG I just received 3 MINIs, I regret I didn’t ordered 30 :’(
This is the light that has the highest happinness/price ratio
Got 8 of these (4 warm white, 4 cool white) from this seller for $1.82 each. I'm really liking them
I keep one plugged into my computer so I can see the CD/DVD Burner. It's dark under my desk.
My two warm white minis arrived very fast from China. Wish I had ordered 20, they are great.
Mini is quite catchy :bigsmile: I gifted a few of them to non-flashlight-addicted friends and the find it interesting also.
Darn, sounds like they can’t be made to turn on as soon as they receive power.
I was thinking of putting a USB power adapter into a switched wall outlet, putting a stiff “worm” style extender on it, and putting one of these lights on the end of that… which would then let me turn it on and off with a wall switch. But if it doesn’t come on when it receives power, that wouldn’t really work.
The plan is to put one or two directly behind my television so it’ll be backlit. I currently have sort of a prototype running, but it can’t be turned off without reaching behind and touching the switch.
Paddington, Lord of All He Surveys, looks out over his domain:
There are some that have no switch and turn on when inserted? Though these are quite bright:
http://www.fasttech.com/product/1558501
Oh, I just checked newly listed and they have 5 cool white for 5.58 USD:
http://www.fasttech.com/products/1/10006956/1741602-6-stw8q14be-100lm-6000-6500k-pure-white-light-usb
They also have the kind with pot and sensor (5 for 5.08 USD, warm white).
I plugged one of my minis in my Raspberry Pi which is on the back of the TV and I just leave it and the Rpi turned on all the time.
I’ll probably just order one (or five) of each, and use whatever works best.
Originally, I was planning to do something much more complicated… but I’m not sure if I’ll ever get time. The plan was to put an XM-L2 or maybe XP-G2 triple or maybe a MT-G2 (at low-ish power) on copper and mount the copper directly onto a CPU heat sink, mount the heat sink onto the back of the television, and run them with some sort of common qlite driver or something, via a power converter plugged into the switched wall outlet. Then I could control the brightness via the wall switch, and it could go up high enough to make regular room lighting unnecessary.
But it’s a lot easier to just stick a USB dongle in and call it mood lighting.
(the photosensitive ones look particularly promising, since I could just leave it powered on all the time)
At this rate, in a year or two, all the batteries we buy will have the flashlights built right in, with the components microscopic under the shrinkwrap.
On the back of my monitor I have an Rgb led strip which eliminates the need for the ceiling light. And I can make it any color I want.
So, I got a bunch of USB fob lights. I’m particularly happy with the touch-sensitive dimmable ones with mode memory (in the OP) and the light-sensitive ones.
I have a light-sensitive warm white one behind my TV and it’s a nice brightness and tint for the steampunk room it’s in. It casts nice shadows on the wall too, since I have a bunch of copper pipes there.
I also set up a cool white dimmable one (on the lowest setting) as sort of a night light in my office. It’s hidden, buried at the base of a bonsai tree on the top shelf of my desk, shining up, where it produces a very nice moonlight effect with shadows up on the ceiling.
Dunno if I’ll keep it, but I’m trying another dimmable one in the bedroom as a night light. It’s a bit awkward though, and still too bright even on the lowest setting, so I may take it out and go back to the trusty old ZL SC52 as a night light instead. Its brightest moon mode is just about right, and a single charge lasts about 6 weeks.
Now I’m out of USB extender cables and “worm” cables and I’d have to dig in my crawlspace to get more phone chargers. But I think what I set up today is enough.
Ordering this one. Both white and warm white versions, 5 of each. Like the user controllable variable output.
Hard to find but I finally did on eBay so I have ordered some in 40 cm or 16” length. Add greatly to USB light versatility.
These just hit the wire at FT
http://www.fasttech.com/products/1/10009843/1864901-usb-powerd-flexible-neck-1-75w-120lm-6000-6500k
If the listed color temperature is correct that is a very warm LED as it claims a 3000K-3500K color range. That is incandescent range IIRC.
Just a small update on a subject of this mini usb. My idea was to use battery pack with this light for camping so I would have a small stationary light that does not need charging for weeks. For this purpose I bought Xiaomi battery pack but, unfortunately, it turned out that this battery pack is not suitable for intended use because when I dim the light, current draw is so small that battery pack just turns itself off and you have to unplug the usb light and then plug it again to work.
You could leave it on max but that is way too much light for small 2-persons tent.
Also, if you leave it on max it will get quite warm, opposite to when it is powered from computer USB port. My usb doctor show that it is sucking 0,17A from computer but 0,20A from battery pack on max.
I have the same problem - also with xiaomi powerbank. It looks like the limit is 0.05A - if the current is lower than that, power bank will cut the power in less than a minute.
My ENB triple power pack has the same issue. I'll only use the ENB triple pack when I need max light for longer times. I have a cheaper/smaller single-cell power bank I use when less light is needed.
